Top speed driving w/o sway bar? - JeepForum.com
post #1 of 8 Old 09-06-2012, 11:35 AM Thread Starter
EarsOfLeather
I need to take my JKU onroad with the sway bar links removed because they're binding on my drag link (due to lift) and the adjustable quick disconnects haven't arrived yet. I need to move my jeep to a different location before the weekend so I'm planning to just remove the sway bar links altogether and drive it about 10 miles.
How unstable am I gonna be on the road? I shouldn't have to drive it anymore than about 30 mph. Any thoughts appreciated!
00 White XJ
32" DuraTracs
3.5" OME lift (HD coils and leafs)
Currie HD track bar & RE quick discos
OME HD steering stabilizer
IRO adjustable UCAs and LCAs
AIRAID intake, 60" safari rack
EarsOfLeather is offline
post #2 of 8 Old 09-06-2012, 11:39 AM
maniacal_rick
You will be fine. The sway bar directly affects body roll, so as long as your not hitting corners at top speed you should be ok.
maniacal_rick is offline
post #3 of 8 Old 09-06-2012, 11:41 AM
gwar11d2
2009 JK Wrangler
You'll probably be ok, but you should take a little caution. 30MPH, no sudden swerving or turns. When you get in on the road just wiggle the wheel a bit to give you an idea of how much body roll you're getting...but at 30MPH going 10 miles I wouldn't worry about it all that much.
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #4 of 8 Old 09-06-2012, 11:43 AM
HappyTrails
It won't make THAT much difference. I forgot to reconnect my sway bar after off-roading one weekend. I was doing 60+, down somewhat curvey roads. I kept wondering to myself why there was more than usual body lean, but nothing so much as to scare me. Wasn't until I got home and later crawled under the front end to look at something else that I realized what I had done.
Just keep in mind that it will lean more and seem to hunt around the road more. But doing 55+ is not a problem.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #5 of 8 Old 09-06-2012, 11:47 AM Thread Starter
EarsOfLeather
Great! That's what I figured but it's nice to have confirmation.
00 White XJ
32" DuraTracs
post #6 of 8 Old 09-06-2012, 11:51 AM
gsaxe
I drive discod on dirt roads frequently at 25-45 mph, itsa nice and cushy, although my lift is only 2.5 and tires 33" aired no less than 20.
AKA Catfish
gsaxe is offline
post #7 of 8 Old 09-06-2012, 12:19 PM Thread Starter
EarsOfLeather
Yeah doesn't seem like it would be a problem unless you were tryin to take corners at high speed or something.
00 White XJ
32" DuraTracs
post #8 of 8 Old 09-06-2012, 12:23 PM
ncb
You'll be ok until you swerve at highway speed to avoid something on the road.
ncb is offline
