Tools to Keep close? - JeepForum.com
post #1 of 30 Old 07-21-2010, 09:29 PM Thread Starter
KJNewbs
1983 CJ7
I'm getting ready for my first road trip (St. Louis to Outer Banks, NC) and am looking to put a small tool bag together to keep in the back. I'm looking for some help figuring out what to have around to be able to take off the hard top, take off the doors, things like that. Any horror stories that end in "man I wish i had ________" would be great. Thanks all.
KJNewbs is offline
post #2 of 30 Old 07-21-2010, 09:36 PM
fernjack
A set of torx sockets an a ratchet/small extenion 3/8" drive would be helpful and a mulit screwdriver with the smaller torx and other standard bits .
fernjack is offline
post #3 of 30 Old 07-21-2010, 09:40 PM
BigRed09
2009 JK Wrangler
a couple flashlights in case you need to get under the hood or vehicle
Mods so far: Mastercraft handles front and rear, Rugged Ridge euro rear tail light guards, Rugged Ridge mirror movers.
BigRed09 is offline
post #4 of 30 Old 07-22-2010, 12:32 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
A hammer a crescent wrench and a fire extinguisher
What I do is whenever I need to get a special tool out of the box i.e. torx for the top or doors, it goes in the cubby in the back!
Jim
JLC08JK is offline
post #5 of 30 Old 07-22-2010, 12:36 AM
AFhockey31
2009 JK Wrangler
After today (not that youll need this on your trip) I realized that the main tools I need to have on a wheeling trip is a 35mm socket, breaker, and 13mm/12 point and 20 mm socket...along with a 3/4 for the wheels. Thats about all you need to pull the wheels and front hub to get the axle shafts out in case of a breakage
Originally Posted by Toms87 View Post
Obviously the kid got farted on by the horse and then the duck pooped out an apple.
2009 Wrangler. XRC 10 winch
RE 3.5" basic lift. Poison Spyder Rockbrawler bumper
35x12.5 KM2. Poison Spyder Rockerknockers
Crager soft 8's. PS diff and evap skids
Bilstein 5100's. Light force 170's
KC Slimlights
AFhockey31 is offline
post #6 of 30 Old 07-22-2010, 12:45 AM
moonshinefuel
Bring one of those tool sets with various sockets, screwdrivers, pliers, etc. Bring vice grips, and a good size cresent wrench, and a decent hammer.
moonshinefuel is offline
post #7 of 30 Old 07-22-2010, 02:14 AM
Warlord2
wire, extra fuses, wire cutters, zip ties, cresent wrench, Multi screwdriver, few sockets, end wrenches, grease gun, air compressor, power bars, flashlights, matches/lighter, hammer, torx set, tow strap and like AFhockey said (he should know) the tools needed for a broken axle/gears.
I bring all that with me and theres probably more I left out....
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #8 of 30 Old 07-22-2010, 05:05 AM Thread Starter
KJNewbs
1983 CJ7
Thanks everyone...regarding the air compressor - i know i'll need to let some air out for riding on the beach, and i've seen some of these smaller compressors for sale - but do these guys have enough to fill 4 tires back up afterwards?
KJNewbs is offline
post #9 of 30 Old 07-22-2010, 05:47 AM
Ravik
2010 JK Wrangler
A lot of guys here run CO2 systems (big can strapped down in the back) for airing up. If you are only needing on board air occasionally, just getting the tank refilled every few months might be more cost effective.
Anyone have one of these and can chime in?
2010 2dr Rubicon
Ravik is offline
post #10 of 30 Old 07-22-2010, 07:14 AM
Warlord2
I have a harber freight like $60 compressor, it airs up my 35" tires from 8psi to 34psi in maybe like 15mins. It really doesnt seem that long at all and I think its great being that is so small and comes with a case. I have used it atleast 10-15 times so far. Thinking of buying another and mounting both under the jeep somewhere and having 1 compressor per 2 tires, having a hose for each tire so I can air them all up at the same time.
Just make sure you get a compressor that connects directly to the battery, not the cigarette lighter.
Warlord2 is offline
post #11 of 30 Old 07-22-2010, 08:58 AM
Tireguy
2009 JK Wrangler
[QUOTE=
Anyone have one of these and can chime in?[/QUOTE]
I've had my CO2 tank (Powertank) for some time now. Don't use it a whole lot, so it doesn't need refilling often, and when it does, its only $1.00/lb to fill it.
Pros- Its very portable, easy to use, and gives the option of using air tools in remote locations. Its has plenty of 'juice' to it for airing up tires and enough pressure to seat a bead. (I aired up 5/6 jeeps' tires after a trail run a few years back, still had plenty left.)
Cons- Initial cost to purchase, it has to be refilled, no way to 'gauge' how much liquid is left (except by weight), tank has to be pressure tested every couple-o-years (bout 15 bucks per test).
Co2 tank vs. mini-compressor? Thats another thread for another day.
Tireguy is offline
post #12 of 30 Old 07-22-2010, 09:09 AM
Rafi
2010 JK Wrangler
haha. bring everything you got!!!!!!!!!!!!!!
Rafi is offline
post #13 of 30 Old 07-22-2010, 09:16 AM
McKBrew
JK Wrangler
The MV-50 compressor is probably one of the most inexpensive and reliable compressors out there. I love mine. It's not overly fast, but usually I'm off doing some other thing on the Jeep and don't worry about the time.
I have a quick tire deflator, so if I slightly overfill a tire, I just let the air out to the desired pressure.
Plus it's really handy when on a trip or at soccer practice for the kids and they need a ball aired up.
McKBrew is offline
post #14 of 30 Old 07-22-2010, 10:13 AM
dave91gt
2009 JK Wrangler
I love the Outer Banks. Anyway, regarding the air, some of the beach accesses have air available. The spot I was on is down near Bodie Island lighthouse. There is a marina or something across the street for air. Anyway, I dont think you should need many tools as you will just be beach driving. The tools for tire changing and top removal should have you set I would think.
10 Explorer
01 Ford Excursion Limited 4X4, 7.3, Superchips, 6637, X codes/F350 blocks, 285 Nitto's
91 Ford Mustang GT, full weight/options, 302 5 speed, 4.56 gear, 8.09 in the 1/8
dave91gt is offline
post #15 of 30 Old 07-22-2010, 08:20 PM Thread Starter
KJNewbs
1983 CJ7
Hey - is this the one that you are talking about? Looks to match the price and comes with the battery clamps:
12 Volt, 150 PSI High Volume Air Compressor
Seems like a good investment for such a small price....
KJNewbs is offline
JK Wrangler , road trip , road trip tools , tools , wrangler
How close is too close??Electric Fan-Radiator clearance ChrisYJ - Italy YJ Wrangler Technical Forum 9 10-29-2009 11:58 AM
getting close Pathogen1337 TJ Wrangler Technical Forum 2 04-24-2008 08:17 AM
89 and 94 how close MeatPuppet YJ Wrangler Technical Forum 1 01-28-2007 09:08 AM
Close to 50k Pipedrummer TJ Wrangler Technical Forum 8 01-27-2007 08:21 AM
Air Tools vs. Power Tools WR4NGLER TJ Wrangler Technical Forum 17 07-13-2005 04:26 PM
