Took the jeep in to get cleaned and got a new cylinder head as well. - JeepForum.com
post #1 of 13 Old 09-30-2013, 09:32 PM Thread Starter
Wrangler98
We took our jeep in this morning for interior/exterior detailing/scotch guarding we got with our warranty. I mentioned the check engine light had come on 3 times in the last two weeks. He pulled the codes, had two #6 cylinder misfire and a random misfire. After further checking they deemed a new head was in order. I had a feeling this might happen, thankfully I have the week off work so I'm not put out by the whole thing. They said it should be done late tomorrow or early Wednesday. I thought I had heard a slight ticking like others had mentioned, but I guess I thought it would be louder. Oh well, at least we will have it back soon.
2012 Wrangler Sahara 3.6/AT
2001 Dodge 2500 CTD/AT
1967 Mustang 5.8/4spd
Wrangler98 is offline
post #2 of 13 Old 10-01-2013, 11:23 AM
zjilla
amen
2007 Unlimited Sahara
98 ZJ Limited RHD (British spec)
USAF Military Working Dog Handler
October 2013 JK of the month
My Slowly but surely JK build thread:
zjilla is offline
post #3 of 13 Old 10-01-2013, 04:05 PM
Powerdriver
How many miles do you have on your Jeep ??
2012 Wrangler Unlimited Sport
2 1/2" dealer installed lift
Tires: 35 x 12.5R18 Nitto Trail Grappler M/T
Wheels: Motor Metal (MO961)
Powerdriver is offline
post #4 of 13 Old 10-01-2013, 05:12 PM
Butterjeep
2015 WK
Better it happens now rather then later, good luck.
2014 Mustang GT Track Pack
2015 WK2 Limited 4x4
Butterjeep is offline
post #5 of 13 Old 10-01-2013, 05:26 PM
-G-
What year do you have?
-G- is offline
post #6 of 13 Old 10-01-2013, 08:19 PM Thread Starter
Wrangler98
It's a 2012, only has 21k miles so far. We just bought it last month with 20k miles.
post #7 of 13 Old 10-01-2013, 08:47 PM
Bayrat
2014 JK Wrangler
Oh it's the new engine, not good news. Hope they covered it.
Bayrat is offline
post #8 of 13 Old 10-02-2013, 12:55 PM
222Doc
222Doc's Avatar
Just had ours done at 20.5K. Took a week to fix and get the new head. They did not stock the heads.
The REAL 500,000$ question are these heads any better? I have seen 013"s with the same complaint.? Did they fix this after the 013 roll out before? If they did fix this before than they fixed nothing if its still happening. It isn't bad fuel. Its that built in exhaust manifold I say. Cooking the exhaust valves in a Jeep I bet its hotter under the Hood then say a Ram or 300.
Just my worthless two cents
I have to say One mod I hoped to wait on at least was going with a Ls and a 6L80e or something in that range. Before I could wear a set of tires Heck the MTR'K have at least another few season's in them might be on my second head by then
222Doc is offline
post #9 of 13 Old 10-02-2013, 06:34 PM
Bayrat
2014 JK Wrangler
I have the 2014 with the basic warranty. Did they cover it under power train or the 36k warranty?
Bayrat is offline
post #10 of 13 Old 10-02-2013, 07:14 PM
00xjsebb
It's the same warranty with the powertrain continuing to be covered after 36,000 miles.
00xjsebb is offline
post #11 of 13 Old 10-02-2013, 10:33 PM Thread Starter
Wrangler98
They told me the new heads were not causing problems, that the issue had been fixed. It was covered by the warranty. We got it back this afternoon, seems to idle smoother now. Just glad they got it done quick and it didn't cost me anything.
post #12 of 13 Old 10-03-2013, 05:53 AM
Wavedatya
2010 JK Wrangler
That's good !
If you ever need work covered under warranty don't be scared to ask them for a rental. Should he covered as well.
OF4WD member #7523. Durham 4x4 member.
Wavedatya is offline
post #13 of 13 Old 10-03-2013, 08:43 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
The heads that come down the line for parts are not from the same sub assembly lot as the heads that come down for complete line assemblies - usually you can see a problem carry to the following year model as the original problem as those complete assemblies (with the earlier sub assembly) get used up.
Not saying this has happened - just a possibility. We saw the same overlap issue with the '90 mitsu 3.6 head eating bearings. Mitsu sent us 250 brand new head assemblies (cam, followers and all) to modify and stock west coast dealers ahead of the change on their sub assembly line... but even some late 90s and early '91s failed for same issue.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
