Too tall for garage - Page 5 - JeepForum.com
post #61 of 139 Old 10-26-2013, 04:34 PM
HappyTrails
HappyTrails's Avatar
Why didn't I think about Zip-Ties? Lord knows, I have over 100 in my Jeep. Almost as useful as duct-tape. LOL!
For about $15 on the spring clips, if you don't like them, it's not much money wasted. Give them a try.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #62 of 139 Old 10-26-2013, 04:36 PM Thread Starter
Tragyn
2011 JK Wrangler
Was just concerned about one popping off mid-turn or something.
Tragyn is offline
post #63 of 139 Old 10-26-2013, 04:40 PM
HappyTrails
Unlikely, especially on a Jeep. Remember, I had these on an RX-7 (sports car) and took some pretty hard/fast turns with those installed. Just be sure to have a second / lock nut added to the threaded bolts so they don't work their way loose.
post #64 of 139 Old 10-26-2013, 04:49 PM
MoonyJohn
Carry a few bags of concrete with you? Something heavy atleast
MoonyJohn is offline
post #65 of 139 Old 10-26-2013, 04:51 PM
HappyTrails
How about a keg of beer instead?
post #66 of 139 Old 10-26-2013, 04:58 PM
MoonyJohn
Just one? How many can you fit in a 2 door?
post #67 of 139 Old 10-26-2013, 05:05 PM
ncb
Get some shorter springs. Looks a bit ridonkulous with so much lift. Looks like it's running really light with only a front stock bumper.
ncb is online now
post #68 of 139 Old 10-26-2013, 05:14 PM
rirrgang
Lower the air pressure of your tires.
-Rick
07 Sahara Unlimited
rirrgang is offline
post #69 of 139 Old 10-26-2013, 05:16 PM Thread Starter
Tragyn
2011 JK Wrangler
Already did that, and now my dash light is on!
Tragyn is offline
post #70 of 139 Old 10-27-2013, 06:24 AM
jski701
http://i.imgur.com/oyZlFzH.jpg
This still looks like a 1.25" or a 1.5" body lift block, on a stock rubber body mount to me. Taking it out is the cheapest solution, maybe not the easiest, for a quick 1.5" or so drop. Half a day project at most (without figuring in the beer factor)
jski701 is offline
post #71 of 139 Old 10-27-2013, 08:01 AM
ncb
Looks like stock body mounts.
ncb is online now
post #72 of 139 Old 10-27-2013, 01:31 PM
jski701
Easier to see in your picture, too bad, would have been an easy fix.
I aint saying its right, but I understand......Chris Rock
My off road trailer build - M416 copy:
jski701 is offline
post #73 of 139 Old 10-27-2013, 01:38 PM Thread Starter
Tragyn
2011 JK Wrangler
It can never truly be easy.
Tragyn is offline
post #74 of 139 Old 10-27-2013, 08:00 PM
suicideking
I'd go with Evo 3" or RK 3.5" springs.
In the meantime, I knew a guy that had a similar problem and put two bags of 60lb concrete in the rear and one 60lb on the floor in the back seat. It was just enough to make it in his garage. You could also use some weights. Just make sure you strap whatever it is down in case of an accident, etc.
suicideking is offline
post #75 of 139 Old 10-27-2013, 08:22 PM Thread Starter
Tragyn
2011 JK Wrangler
I think I might just pull the trigger on the proper springs. Will I have to change anything else? I read something earlier that said some shocks are for a certain amount of lift. If my shocks are too long then that's more money to spend...
Also, apparently there are lower points in my garage than I was aware of. Caught the top of the jeep on a part of a pipe... put a good dent in it and tore part of the soft top.
Yay, new Jeep!
Tragyn is offline
