Too tall for garage - Page 2 - JeepForum.com
post #16 of 139 Old 10-25-2013, 04:45 PM
HappyTrails
No, look at the COIL springs. Not the shocks. May have to wipe some dirt off them to find the writing. Btw, I hear the Rancho shocks have a nice soft ride. Ok, those look like stock lower control arms. And no AEV drop brackets.
2008 2-dr Rubicon, auto,
RK 2.5" Max Travel, Rancho 9000XL shocks, 37" Nittos, 5.38's, RR skids, Warn VR8000-S.
RIPP Gen 2 Stg 2 Supercharger.
Political Correctness offends me.
HappyTrails is offline
post #17 of 139 Old 10-25-2013, 04:47 PM Thread Starter
Tragyn
2011 JK Wrangler
Ah, gotcha. I'll go take a look.
Tragyn is offline
post #18 of 139 Old 10-25-2013, 05:16 PM Thread Starter
Tragyn
2011 JK Wrangler
Tragyn is offline
post #19 of 139 Old 10-25-2013, 05:24 PM
krawler510
Yeah, you're at a solid 5.5" of lift. That's pretty harsh on a 2 door.
What size tires are on it? You could easily drop some shorter springs in and be fine.
Rough Country makes those control arm drop brackets too.
'The early bird may get the worm, but the second mouse gets the cheese.'
krawler510 is offline
post #20 of 139 Old 10-25-2013, 05:27 PM Thread Starter
Tragyn
2011 JK Wrangler
5.5"...that's huge. What do I need to replace in order to drop down to about 3.5"?
Also, my shocks appear to be RS9000, not RS5000. So that's pretty cool..
Tragyn is offline
post #21 of 139 Old 10-25-2013, 05:28 PM
HappyTrails
Yeah, I was going to say 4.5" considering you still have stock control arms. That is a lot of lift for a 2-dr on 35's. You can buy some Rock Krawler coil springs (go with 2.5") and you'll be looking good. On a 2-dr, 2.5" = more like 3.5" esp with no winch and stock bumpers.
With as much lift as you have, I'd be worried about the driveshaft angles.
post #22 of 139 Old 10-25-2013, 05:33 PM
krawler510
You have a lot of spring options.
As said above Rock Krawler 2.5 will give you. 3.5-4".
Popular choices:
AEV 2.5 or 3.5"
Teraflex 2.5 or 3"
Evo 3"
All will fit 35s especially with those cut fenders.
post #23 of 139 Old 10-25-2013, 05:34 PM Thread Starter
Tragyn
2011 JK Wrangler
Awesome, thanks guys! Anything I should know (tips/tricks/warnings) about swapping these out? Looks fairly straightforward.
Tragyn is offline
post #24 of 139 Old 10-25-2013, 05:46 PM
HappyTrails
Removing the lower bumps stops (those round black things at the bottom/inside the springs) first will make spring removal easier. Just jack it up, put jack stands under the frame, and let the front axle droop the maximum possible, and pull out the springs, replace them with new springs, re-install bump stops, jack axle back up, remove jack stands, lower axle back down. You're done.
post #25 of 139 Old 10-25-2013, 05:48 PM Thread Starter
Tragyn
2011 JK Wrangler
Originally Posted by HappyTrails View Post
Removing the lower bumps stops (those round black things at the bottom/inside the springs) first will make spring removal easier. Just jack it up, put, frame stands under the frame, and let the front axle droop the maximum possible, and pull out the springs, replace them with new springs, re-install bump stops, jack axle back up, remove frame stands, lower axle back down. You're done.
Nice! Sounds simple. Unlike my motorcycle...
Tragyn is offline
post #26 of 139 Old 10-25-2013, 05:53 PM
HappyTrails
Yep, it is pretty straight forward. Take you less than 5 minutes to swap them once you have it jacked up.
post #27 of 139 Old 10-25-2013, 05:56 PM
DangFoo
Have the water and sewer pipes removed from the building; clearance problem solved. Who needs indoor plumbing anyway - people lived Centuries without it and still do in many a 3rd World country [much of Africa].
DangFoo is offline
post #28 of 139 Old 10-25-2013, 05:59 PM Thread Starter
Tragyn
2011 JK Wrangler
For a brief moment I considered moving them...
Does anyone have an opinion on this kit? http://www.ebay.com/itm/Suspension-S...53cfa8&vxp=mtr
Tragyn is offline
post #29 of 139 Old 10-25-2013, 06:04 PM
krawler510
Odds are that to swap springs you'll need to unhook the shocks and sway bar. Unless you use strut compressors.
post #30 of 139 Old 10-25-2013, 06:09 PM Thread Starter
Tragyn
2011 JK Wrangler
That's not a problem, I haven't looked at the hardware but I'm certain I have the tools for it. I've seen someone screw up with a strut compressor once...that wasn't pretty.
Tragyn is offline
