-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Too tall for garage (http://www.jeepforum.com/forum/f96/too-tall-garage-1722338/)
Tragyn 10-25-2013 03:33 PM
Too tall for garage
So I just picked up my jeep and it's a bit too tall for my parking garage. I can get in but some low hanging pipe rubs on the center bar of the soft-top. If I have the top off I fit no problem.
It's clearly lifted, but I really don't want to get rid of the lift if I don't have to. Is there anything I can try? A slimmer soft-top? Or, maybe, can I take that center bar out of the top without causing any issues (I imagine it would just get noisy on the highway).
Any help is appreciated.
http://www.hyundaionhuntclub.com/ott...rt-26743-2.JPG
As you can see, the bar in the center is about .5 to 1" taller than the rest of the truck.
Kiriesh 10-25-2013 03:58 PM
You can try a frameless soft top or always have a friend with you haha
Sent from my SAMSUNG using JeepForum
KYgreenYJ 10-25-2013 03:59 PM
That lift seems tall, you could maybe get shorter springs, any idea what lift is on it currently?
Tragyn 10-25-2013 04:05 PM
I'm not sure. I've gotta get a better look at the parts and see if I can measure it out.
I haven't taken it off-road yet, nor am I familiar with doing so with any vehicle. I don't know what kind of clearance I need; can I sacrifice a couple inches of lift without cashing my wheels to rub anything?
Tragyn 10-25-2013 04:06 PM
I'll look into a frameless top as well. That's a good option. I managed to get my framed soft-top on and off by myself, which was kind of a pain in the ***. Would prefer not to do that every time. ;)
AlbertaJeeper 10-25-2013 04:15 PM
You could use this an excuse to buy an on board air system. Then air down outside and drive in and park. Then air up once out! My choice would be to decrease the lift a bit though, that looks pretty huge!
Tragyn 10-25-2013 04:17 PM
Hmm, if dropping the lift won't cause any issues, then that may be the best idea. How can I identify the type/size of my lift? That way I can know what to measure, and what to order to replace it.
HappyTrails 10-25-2013 04:25 PM
Wow, looks like quite a lot of lift, maybe 4"-6". But the tire size may exaggerate it. Look, I have only 2.5" and am running 37" tires with flat fenders. You can certainly afford to go down in lift.
The tire size is what gives the axles (the lowest part of your Jeep) more clearance. The lift kit just raises the frame & body higher. I would ask a local 4x4 shop to take a look-see and tell you what lift kit you have.
Do you know what size tires you have? Generally, 35" tires will get you most anyplace. And 35's only need 2.5" of lift to run most trails.
Looking at it more closely, it appears to be an AEV 3.5" lift kit. Why? Looks like you have front lower control arm drop brackets and the lift is pretty tall (3.5"+).
Tragyn 10-25-2013 04:28 PM
Originally Posted by HappyTrails (Post 17152826)
Wow, looks like quite a lot of lift, maybe 4"-6". But the tire size may exaggerate it. Look, I have only 2.5" and am running 37" tires with flat fenders. You can certainly afford to go down in lift. The tire size is what gives the axles (the lowest part of your Jeep) more clearance. The lift kit just raises the frame & body higher.
I would ask a local 4x4 shop to take a look-see and tell you what lift kit you have. Do you know what size tires you have? Generally, 35" tires will get you most anyplace. And 35's only need 2.5" of lift to run most trails.
I've got 35" tires so I think I'm good there. I didn't think I had that much lift, but if that's the case then I can definitely lower a couple inches. How can I figure out which kit I have? If I know what parts to look for, I can crawl under and measure!
HappyTrails 10-25-2013 04:29 PM
Re-read my previous post. Just added another bit to the end. Specifically, behind your front tires, there are two long bars going from your axle to the frame. Those are the front lower control arm
s. Is there a bracket that comes down from the frame and then attaches to the rear part of those arms?
Or look at the springs. Is there any kind of writing on them?
Jeffro06 10-25-2013 04:30 PM
I'd do shorter springs too....that's overkill for those tires. I'd also spray the body below the flares black.
TripLeader 10-25-2013 04:32 PM
Not a Jeep Problem, It's a Garage Problem
1 Attachment(s)
Dig 3 inches out of the garage floor.
HappyTrails 10-25-2013 04:33 PM
Install a lift kit on the garage! A BB or BL should do the trick.
Lenny7 10-25-2013 04:41 PM
Get a big ol steel front and rear bumper with tire carrier. That might sage I enough. :thumbsup:
Tragyn 10-25-2013 04:42 PM
Says Rancho RS5000 on 'em. I'll grab some more pictures of the underside in a an hour or so when I can get out to it. Here's what I have from before.
Thanks for all the help so far!
http://i.imgur.com/33bJpyQ.jpg
http://i.imgur.com/zMaYPlf.jpg
http://i.imgur.com/CACMpIh.jpg
http://i.imgur.com/gcf6aec.jpg
http://i.imgur.com/I8gPPya.jpg
http://i.imgur.com/oyZlFzH.jpg
The time now is 08:10 AM.
Resources saved on this page: MySQL 0.96%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
