TJ vs JK Frame Width? (outside to outside) - JeepForum.com
post #1 of 7 Old 01-18-2010, 04:02 AM Thread Starter
djleathal7
2011 JK Wrangler
Does anyone have the outside dimensions for a JK. Building a custom bumper and was wondering if I trade in my 06 Rubicon for a 2010 JK if I would be able to transfer the bumper or would I need to Mod it. Thanx in advance, Djleathal7.
djleathal7 is offline
post #2 of 7 Old 01-18-2010, 11:09 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
The front frame is aprox. 33" outside dimension, The rear is aprox. 46".
I think they are setup differently than your TJ and would require much modification to change over.
Jim
JLC08JK is offline
post #3 of 7 Old 10-08-2010, 10:33 AM
4LCKDRUBIUNLTD
2010 JK Wrangler
Alright I need help... I am going or thinking about fitting a TJ Mopar rock crawler bumper onto my JK. What I need is the measurements from a TJ. I need the front bumper frame widths. Pictures would help also. Thank you my fellow Jeepers!
4LCKDRUBIUNLTD is offline
post #4 of 7 Old 10-09-2010, 07:50 AM
thedirtman
thedirtman's Avatar
I have built bumpers for both models front and rear andy they are completely different on how they mount. If you are going to use a tj bumper on a jk all you need to do is drill 8 holes in the bumper for the bolt mounts or weld some bolts to the back side. The JK bumper mounts where the tow hooks are on the factory bumper. You should be able to adapt it with a torch and welder.
If you learned something new today, you had a good day.
thedirtman is offline
post #5 of 7 Old 10-09-2010, 09:27 PM
4LCKDRUBIUNLTD
2010 JK Wrangler
Thanks for the reply Dirtman. That bumper you built is .
post #6 of 7 Old 10-10-2010, 10:06 AM
thedirtman
thedirtman's Avatar
Thanks. Here is the rear. The rear ones are much easier to build. We did my buddies tj in about 30 min.
post #7 of 7 Old 08-15-2013, 05:38 AM
Elyankee
sorry for getting into this thread like that but im trying to do the same thing but im trying to fit a jk bumper into a tj so what would i need to know how wide is jk from the outside flare to the outside flare and also how wide is the frame .... any info would be fully appreciated it by the way is a front bumper
Elyankee is offline
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 01:34 PM
Full width to full width (9 inch to dana 60) hmmhoyhoy YJ Wrangler Technical Forum 0 08-01-2009 03:45 PM
Frame Width TellyDSP YJ Wrangler Technical Forum 5 09-26-2007 04:16 PM
front frame rail width? rwmjeepjk JK Wrangler Technical Forum 0 03-02-2007 09:13 PM
