???? for TJ /JK Rubicon owners - JeepForum.com
post #1 of 15 Old 11-12-2006, 03:58 PM Thread Starter
PLAN D
Is it true the F/R lockers can only be activated in 4 Lo? If so is it poss. to rewire so they can operate in 4 H as well?
PLAN D is offline
post #2 of 15 Old 11-12-2006, 04:45 PM
BeerMonkeY
tj switchs can be "fixed" to work in 4hi but as far as i know there isnt any fixes for the jk ,yet. i hop someone figures out how to do it soon though
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
BeerMonkeY is offline
post #3 of 15 Old 11-12-2006, 05:23 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
It is definitely true for the TJ. I can't say for sure on the JK, but I doubt it would be any different. There is a fix for the TJ, but I haven't seen anything for the JK Rubi... yet
I'll be Savvy someday!
neZZr is offline
post #4 of 15 Old 11-12-2006, 06:22 PM
EagerJeeper
I read an article on www.stu-offroad.com about fooling the computer. Jumpers were used behind the switches. Wouldn't it be easier to catch the wire coming out of the transfer case and use a switch on the dash to mimic the state of 4LO?
EagerJeeper is offline
post #5 of 15 Old 11-12-2006, 06:41 PM
neZZr
neZZr's Avatar
I'm not sure how that would be easier... there's like 2 wires behind the dash to change.
Here's the instructions (for TJ)
http://www.rockcrawler.com/techrepor...pass/index.asp
neZZr is offline
post #6 of 15 Old 11-12-2006, 07:24 PM
EagerJeeper
Ok you win!
post #7 of 15 Old 11-12-2006, 09:48 PM
neZZr
neZZr's Avatar
That said, it may be a simple mod, but I still have yet to do it to mine
neZZr is offline
post #8 of 15 Old 11-13-2006, 12:33 AM
2002RockHog
looks like I'll have a project for tomorrow...
07 JK Rubi 4DR, Rescue Green, 38.5 Swampers, Exo-Cage, Modified K&N, Glasspack, modified 4" Skyjacker
Past...
2002 TJ Rock Crawler (sold to Adam)
Fill width Dana 60's Detroits 5.38 full floater
Poison Spyder cage, exo cage, 40" Swampers
2002RockHog is offline
post #9 of 15 Old 11-13-2006, 09:25 AM
03jeeper78
03jeeper78's Avatar
I know this is a popular mod for the TJ Rubicon, but just out of curiosity, when would you want the axles locked in 4hi?
'03 Bright Silver Metallic TJ Sport
BSMCCEP Club Member #45
Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group
Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount
Next : Jeeperman rear bumper
'06 Candy Orange Honda Shadow Spirit 750
03jeeper78 is offline
post #10 of 15 Old 11-13-2006, 09:29 AM
2002RockHog
Sand for me, mud for others. My JK probably wont even make it up competition hill without this mod. You need momentum to get up there and if the lockers are not on, no go to the top.
You need those wheels spinning to move.
Past...
post #11 of 15 Old 11-13-2006, 11:12 AM
03jeeper78
03jeeper78's Avatar
I always forget about sand. Not much of that around here.
post #12 of 15 Old 11-13-2006, 08:28 PM
BeerMonkeY
yes,get to work
'92 YJ
'98 ZJ 5.9
'13 WK2 HEMI
post #13 of 15 Old 11-13-2006, 08:43 PM
jdrogers
Did you work on this today? I suspect it's going to be much harder on the JK.
I did this mod on my 2004 but I haven't done anything about it on my JK since the FSM is not yet available. I believe the switches (i.e. locker switch, sway bar switch, etc.) are one closed module on the JK, not separate switches like the TJ so you will have to decipher the wire colors in the connector.
The whole dang switch might just be inputs to the CAN bus and the ECM or something does the actual signaling to the lockers.
2002 WJ Limited, Stone White, 4.7L H.O., Quadra Drive
OME Springs, MX6 Shocks, BFG 265/70R17 All-Terrain, Level 8 Tracker Wheels
Scottsdale, AZ
jdrogers is offline
post #14 of 15 Old 11-14-2006, 08:15 PM Thread Starter
PLAN D
In these instructions it states that by rewiring the switch you are fooling the computer into thinking that the x-fere case is in 4lo. If that is the case, does the same thing go for the swaybar disconnect.
PLAN D is offline
post #15 of 15 Old 11-14-2006, 10:52 PM
2002RockHog
No, I made the stinger today instead. But its definately a mod I will be trying before this weekend when I leave for Pismo.
Past...
Rubicon TJ vs. Sahara TJ -- Rubicon owners chime in! retromag123 TJ Wrangler Technical Forum 44 12-11-2009 08:18 AM
Rubicon owners help please amp77 TJ Wrangler Technical Forum 8 01-13-2007 09:03 PM
for rubicon owners rubiconobi TJ Wrangler Technical Forum 19 10-13-2006 10:16 AM
FYI Rubicon Owners RussT TJ Wrangler Technical Forum 0 10-28-2003 08:53 AM
For Rubicon Owners Instaurare TJ Wrangler Technical Forum 0 06-13-2003 04:59 PM
