tj bumper on jk - JeepForum.com
post #1 of 11 Old 02-26-2013, 09:33 AM Thread Starter
pnk
tj bumper on jk
Ok dudes got a bumper given to me. It's a tj stinger bumper but I have a jk. Now before I just pitch it to a buddy of mine is it possible to put on the jk without too many headaches. Keep in mind I don't have much of a fabrication back ground.
pnk is offline
post #2 of 11 Old 02-26-2013, 09:34 AM
jrallen
Nope.
jrallen is offline
post #3 of 11 Old 02-26-2013, 01:03 PM
awinski
depending on how its setup. could be easy, could be frustrating. the jk mounts with front holes. youd have to do some drilling, but i imagine that should be the extent of it.
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #4 of 11 Old 02-26-2013, 06:59 PM
thedirtman
thedirtman's Avatar
Should not be a problem if you have any fab skills.
If you learned something new today, you had a good day.
thedirtman is offline
post #5 of 11 Old 02-26-2013, 08:18 PM Thread Starter
pnk
So were talking a few holes to be drilled and maybe a plate or two to be able to put it on rather easy.
pnk is offline
post #6 of 11 Old 02-26-2013, 08:56 PM
Prot
Prot's Avatar
2014 JK Wrangler
I think the JK's frame rails are significantly wider than a TJ's. For it to work and be solid, you would have to modify the mounting to accommodate width. You would probably have to also eliminate the JK's crush cans. Neither modification is a big deal, but if you don't have a welding machine, torch, saw, and grinder then you are SOL.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #7 of 11 Old 02-27-2013, 03:18 AM
awinski
lets get a pic of the bumper, and some measurements, thatll decide ow hard itll be
awinski is offline
post #8 of 11 Old 02-27-2013, 09:48 PM Thread Starter
pnk
Will try to pull some tomorrow at work. My buddy drives a tj. Told him to bring it tomorrow.
pnk is offline
post #9 of 11 Old 03-11-2013, 11:20 AM Thread Starter
pnk
Ok so moral of the story is it can be done if you have the fab tools and no how. Unfortunately for me I have neither so the stinger went on his jeep yesterday.
pnk is offline
post #10 of 11 Old 03-11-2013, 01:28 PM
HISSMAN
2011 JK Wrangler
I can make a mustang front end fit onto my JK. With enough fabrication anything is possible. The best thing for you to do is get out the tape measure and camera. Measure and take pics of everything and spec out exactly what you think needs to be done in order for it to fit. Once you do that, next come up with at least two other ways of doing it. I have found that it is usually the third way that works best.
-Jeff
HISSMAN is offline
post #11 of 11 Old 03-11-2013, 01:31 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
-Jeff
All that and then some, deciding the third way works best is usually right after completing it the second way... or as I used to proudly say - "in the custom world NOTHING fits or looks good until ya f... with it for an hour"
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
