tires sensors question JK - Page 2 - JeepForum.com
post #16 of 22 Old 01-21-2014, 01:54 PM
Original_Junior
Originally Posted by BruceM1964 View Post
Correct they do tell you the pressure of each individual tire. This brings a question to mind and that is are these devices addressed, in other words is the left front sending unit programed to be just that, a left front sending unit. If so what happens when you rotate tires. Are they automatically readdressed to the new location some how.
After a rotation, you usually have to re-learn the sensors. Since I do not have this function in my Jeep, I am not positive but recently on a Ford van I had to do this. It is easy and documented in the owners manual. I imagine Jeep's is not much different. Usually the dealer will do this but if you rotate your own you will have to do it. In reality, it should not be a concern on our Jeeps since the pressure is suppose to be the same in all four tires. On the Ford van, the rears were 5 lbs higher thus throwing the sensors off when I adjusted the tp accordingly.
Original_Junior is offline
post #17 of 22 Old 01-21-2014, 01:56 PM
ridesno4llfe
Caught my curiosity. Checked my build sheet and its part of the connectivity group.
Everytime I sell a jeep I say no more then a new one shows up in my driveway
ridesno4llfe is offline
post #18 of 22 Old 01-21-2014, 01:57 PM
ridesno4llfe
It is posted around that the jeeps just have to be driven to relearn. No dealer or tpms tool required.
post #19 of 22 Old 01-21-2014, 02:39 PM
JIMBOX
We were talking about the AEVPM and it doesn't tell you the individual tire pressure--the jeep ECU does if it's not disabled !
Originally Posted by ridesno4llfe View Post
They do on the 2013 and up
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #20 of 22 Old 01-21-2014, 03:04 PM
BruceM1964
The premium "tire pressure monitoring system" does tell you the individual tire pressures, it shows up in the EVIC.
BruceM1964 is offline
post #21 of 22 Old 01-21-2014, 06:58 PM
JKinBlack
JKinBlack's Avatar
2014 JK Wrangler
My Rubicon X does tell individual pressures. I have also switched out my stock wheels / sensors for aftermarket wheels / aftermarket sensors. I paid $20 each for sensors on Amazon. I took the rims / tires / and sensors to the shop and had them mounted and balanced. Brought them home and put them on my Rubi. By the time I backed down the driveway into the road to go for a test spin, the low pressure light had already gone out and all 4 pressures were showing in the EVIC.
2016 JK Rubicon Hard Rock
Past Jeeps:
2014 JK Rubi X, 2008 JK, 2002 TJ, 1993 YJ
JKinBlack is offline
post #22 of 22 Old 01-21-2014, 09:03 PM
Demp
Correct, after rotation it may take a few miles but they will correct themselves.
Same goes for a low pressure trigger, sometimes it takes a few miles to stop bugging you.
As others said I believe the EVIC is required to see the pressure, otherwise you only get the warning light if something is wrong.
Demp is offline
