#1 | |
Tire rub?
Hi
I recently bought my JK unlimited and it came with a 2" lift the dealer installed and new BFG AT 235/75R16 tires. Looking at the "will it rub" topic I should have no problems. But when I turn the wheel over hard I can hear and feel what seems like the tire treads rubbing something. Parking with the wheel turned shows clearance between the wheels and anything close they could be coming in contact with. Any ideas what I should look for? Thanks!
My Jeep: 2007 Wrangler Unlimited X. Rescue Green, 6 speed. |
#2 |
wow. those are pretty small tires to be rubbing. 235/75 are about 29.9 x 9.3 inch tires. those are actually smaller than the factory tires. they must look pretty crazy with the 2 in lift.
id check something other than rubbing issues. check the wheel bearings and make sure they are ok.
09 JK 4 Door Rubicon, Jeep Green 35" Goodyear Duratrac, 3.5" Rock Krawler springs and control arms , RC 2.2 Shocks. TNT customs front stubby bumper with Warn 9000 lb winch If I Wanted A Hummer I Would Have Asked Your Mom For One |
#3 |
Hmmm. If its bearings I will have something to say about it. Unfortunately I am at work for 3 more days but I will play around with it more when I get home.
I didn't realize they were smaller tires than stock. With 98,000km I am sure the original tires are long gone but the current spare is a Goodyear of the same size that was on the Jeep the first time I drove it. They put the lift and BFGs on while it was still on the lot for sale. I will run these tires down then explore my options when its time for new ones. I see that "stock" was a 32" tire... Thanks for the suggestion!
My Jeep: 2007 Wrangler Unlimited X. Rescue Green, 6 speed. Last edited by VIJeeper; 09-12-2009 at 11:52 AM.. |
#4 |
Also, check the factory Air Dam in the front, when I had 33s making a left U-turn I'd catch the lip of it and scrape. If it's that, it's a very simple trimming job and the problem is solved.
AEV: Hood, Skidplate & Bumper, jackstand and Badging Expedition One Rear Bumper,RE 4.5" Long Arm Kit,5.13s, Black Riddler Diff Covers, Hypertech Airaid CAI, PIAA 540s w/flush mounted switch, Flowmaster 40, 325/60/22 BFGs and the list goes on... |
#5 |
my jk came stock with 225/75/16 so tire are stock most like. when install lift and tires i had rubing with skirting under bumper. but did not rub before i did this. but i also but on lager tires. went to 315/75/16. are your wheels stock wheels.
07 jk unlimited, 4" rough country, 315/75/16 mt atz |
#6 |
as far as I know they are the stock wheels. I have not figured out how to post a larger picture other than whats in my profile.
#7 |
lift the front end up (put e-brake on) and then turn the wheels to the sides, then by hand turn the wheels to see whats rubbing or where the noise is coming from.
#8 |
Oh good idea I will try that...easier than having the wife drive in circles while I try to look and not get run over!
#9 |
hehehe....
that would be a funny video... I just had a visual |
#10 |
Ok I messed up. I should have rubbed the rest of the mud off the tire! They are 285/75r16 which makes them pretty close to a 33" tire...which according to the faq says there may be some rubbing!
I tell you though this forum is helping me learn lots about my Jeep! Thanks!
#11 |
I Live, I Ride, I Am
So the dealer installed a lift and tires and didn't check the "will it rub" sticky at Jeepforum first?
#12 | |
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way. 2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(My Build Details) |
#13 | |
JF Administrator, eh?
Hello, my name is Vance and I am a Jeepaholic. Its better to be naked with your friends, than to be clothed with your enemies #1 From street to trail, '88 YJ on 38" tires does it all well #2 Silver 2006 TJ Unlimited, zombie ready as the daily-driver .. and now a Kawasaki KLR650 DualSport bike TEOTWAWKI |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
