Tire Pressure System Reading Low - JeepForum.com
post #1 of 10 Old 11-18-2013, 08:27 PM Thread Starter
JeepWJ24
The other day my dash alerted me that I had low pressure in my tires. I manually checked all tires, and they're all where they need to be.
Any reason why the system may be going off? Does it have anything to do with the weather getting cold?
JeepWJ24 is offline
post #2 of 10 Old 11-18-2013, 08:35 PM
ronjenx
ronjenx's Avatar
What year JK do you have?
Does the TPMS display give an actual pressure reading and tire location?
If the tire pressure is where it needs to be, as it says on the tire pressure placard on the door post, then it has nothing to do with it being cold. The cold will cause the pressure to drop and you would see that on your tire pressure gauge. How did your reading compare with what's on the placard?
I have had mine throw an alert for no apparent reason several times over the years. It's still a mystery to me why it does that.
ronjenx is offline
post #3 of 10 Old 11-18-2013, 10:21 PM
1222
RIP John
1222's Avatar
I had that problem on my í08 a couple of times. Pressure was fine but I added more just to see if the light would go out and it did. Later I would adjust the pressure back to where it was and problem was gone. I donít know why it did that and never gave it much thought either; to many other things going on in my life to worry about it.
1222 is offline
post #4 of 10 Old 11-19-2013, 06:18 AM
Jiblet
you have tpms in a 2000 WJ?
or did you get a JK but not change profile? If so what year, etc.
Jiblet is offline
post #5 of 10 Old 11-19-2013, 07:27 AM
captainstabbin
Check your spare tire...
captainstabbin is offline
post #6 of 10 Old 11-19-2013, 07:44 AM
JIMBOX
I haven't had any problems with my TPMS system in over 5 years-
I disabled it with the AEVPM-
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #7 of 10 Old 11-19-2013, 08:26 AM
Mlarv
2014 JK Wrangler
If I am not mistaken the TMPS sensors are rated for around 7 years battery life. They normally are on a band around the rim and some are on the valve stem. With that said if you checked all the tires and they where correctly inflated, then you may have a sensor starting to go bad.
Here is some pretty good information on them.
http://www.titantpms.com/index.html
What Would Scooby Do?
Mlarv is offline
post #8 of 10 Old 11-23-2013, 03:56 PM
Butterbuddha
2010 JK Wrangler
WJ or JK they work the same. Only difference is you can't disable TPMS on a WJ without replacing the entire EVIC with a non TPMS model
You still have concerns about battery life, and you should remember to check your spare. Though in a WJ you would KNOW which tire is low, their TPMS is way fancier than the JK dummy system.
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #9 of 10 Old 11-26-2013, 03:46 PM
Maertz
2009 JK Wrangler
this x 2..
Wishing I Wasn't Part Of The 'JK' Crowd...
Maertz is offline
post #10 of 10 Old 11-26-2013, 04:58 PM
sean0168
2014 JK Wrangler
I recently had the same problem in my brand new 2014 with after market tires and rims. I just plunged in my AEV procal and shut the tire monitor off.
sean0168 is offline
