tire pressure monitoring system
| The Original 3/8" Ruffstuff Diff Cover! | Ruffstuff Axle Simple Swap Kit! | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
just bought a set of 17x9 wheels and 35" km2's......how will that affect that system? what do I have to do? I just realized this after ordering the wheels. is there anything I have to swap out of the factory wheels and tires to the new set? anything? I am pretty new to the Jeep thing and my Jeep only has 230 miles on it! I don't want to mess anything up on it
09' Sahara Unlimited in SUNBURST ORANGE, OME HD suspension lift and M.O.R.E. 1" Body lift, ProComp 17" 7189's BFG 35x12.5x17 KM2's, Superior 5.13 Gear's, AEV Snorkel, Custom KMA Light Bar w/6 IPF's, Cobra 75 WXST cb w/4' Firestick, JKS Quick Disco's, TeraFlex Steering Damper, MBRP Relocation Exhaust, Bestop Trek Top, LoD sliders/front mid-width bumper/rear bumper w/swingout |
#2 | |
just move the sensors from the stock wheels to the new wheels.
for details and info on our JK's, check out http://n2rock.com His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list Hers: '08 X Red Rock, soft top, auto. Bunch of mods Quote:
#3 |
your factory wheels have tire pressure monitors in them which is a sensor built into the valce stem . you'll need to swap this over to your new wheels as long as they will mount to the new ones and make sure your tire pressure is set correctly. the worse that will happen is you will have a tire pressure light on
#4 | |
#5 |
Tire size won't change how the sensors work. Pressure is pressure. A larger tire with more air volume won't change how it works.
#6 |
Retired from Forum
Just one piece of additional advice... Don't use metal valve stem caps.. Only plastic or TPMS approved.... There is a "galvanic" effect with the valve stem and the caps will corrode shut.
(Next step, they cannot be removed, vise-grips, broken TPMS. Hence, $ 40.00 to replace.. )Check out this thread as well... |
#7 | |
thank you everyone for all your advise! ![]()
#8 |
USAntigoon is soooo right on the valve caps. I know this first hand and you don't want to deal with that. Believe Me
2009 Sahara 2dr 2.5" RC coil lift, DCl 16x8 wheels, DC FCll 285/75R16 tires, Rampage Recovery bumpers F & R |
#9 |
I did not know about the metal valve cap thing. We just put some on ours, will have to check them.
~Michael Her New Ride: 2012 4 door Rubi in Dozer Yellow/Orange - Stock for now. |
#10 |
Trust me on this and it's true. GET PLASTIC CAPS!!!!!!! I spent about two hours slowly grinding metal caps off all four of a friends valves because they were totally siezed up. PITA seriously, They look nice but get them off.
#11 | |
I'm glad I read this thread! My wife's JK is an '08, and we put my wheels & tires (an '07 without TPMS) on it last year. We did not move the TPMS just because of the hassle. But I'm taking it in this weekend to have it done finally. And she has some purty red metal caps on there right now. Guess I'll have to break the news to her that she'll need to ditch those.
#12 |
I'm sure it does not happen to all metal caps out there but if you are the one that it does happen to it will suck big time
#13 | |
her caps are aluminum... Not sure if that makes any difference.
#14 |
this is a very useful thread, as we just got an '07 JK and we'll be starting to fix it up!!!
'99 TJ 4.5" Rubicon Express Short Arm lift, JKS 1.25" BL/MML, D44's with 4.88's and ARB's, Longfiled axle shafts- front, Superior axle shafts -rear, 35" KM2's on Allied beadlocks, NV241, Rokmen gas tank skid, Gen Right rockers and corner panels, Warn Powerplant winch, Currie heavy duty steering w/Doetsch Tech stabilizer '07 4-Door JK Rubicon - BONE STOCK (for now) |
#15 |
Retired from Forum
The TPMS valve stems are having a different alloy then the regular ones.. Keep in mind they act as a small antenna to give the monitor system a signal.. Aluminum will create a galvanic effect with the stem material particularly with the very tiny charge on the stem...
The caps I got with my new tires (where they replaced the TPMS sensors) looked like alu but where in fact plastic.. My suggestion... Get some nice plastic caps, take her favorite nail polish or buy some "purty red" and she will not even notice.. ( I hope) N2rock, don't act funny once you buy this "purty red" nail polish... ![]() |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
