tire pressure for BFG KM2s 35's 2D - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > tire pressure for BFG KM2s 35's 2D
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 08-24-2008, 08:22 PM   #1
BiGEN
so what has everyone with the 35 KM2's on the 2drs been running.. im prob running to low.. i keep it at 32... and 25 for offroading...
FOR SALE!
R.E. Monotube Shocks - $200 NEW PRICE
VAJeepTrailDogs
[/color]
BiGEN is offline   Reply With Quote Quick reply to this message
Unread 08-24-2008, 09:16 PM   #2
LHS-Cowboy
DETN8R
LHS-Cowboy's Avatar
I've got a 4-dr, but I run 30 psi empty on the road and 15 psi on the trail.
'08 DETN8R Yellow Unlimited Rubi
6-Spd / Soft top / Power
Installed:
R.E. Modified 3.5 Super Flex Kit to 4+/Ft. & Rr. U-joint driveshafts/Full Traction Rear Adj. Trackbar/Custom Ft. Heim Joint Adj. Trackbar/Rancho 9000XL shocks/Yukon 4.88 Gears & Superior Rear Axle Shafts/37" Pitt Bull Rockers on Custom Allied Beadlocks/Poly Perf. Rock Sliders/Shrockworks Mid Ft. & Rear Bumper/Custom Trans. Crossmember and Skid/Custom High Steer with PSC Hydro Assist/Plumbed Warn PowerPlant HP/Cobra 75 WS XT C.B./Bully Dog Programmer/Custom Exhaust/Dual Optimas/48" X-treme Hi-Lift Jack on Custom Rear Swing Away Carrier/...
____oooo
[ l_,[____],
l---L -[
OlllllllO]
( )_) ( )_)--)_)
LHS-Cowboy is offline   Reply With Quote Quick reply to this message
Unread 08-25-2008, 06:53 AM   #3
N2rock
Exactly the same for me- 4dr running 30 on road, 15 on the trails. When I first bought them the shop had them at 37psi, and it road rough as hell. At 30psi they are soft enough to absorb alot of the road bumps.
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote Quick reply to this message
Unread 08-25-2008, 11:43 AM   #4
BRICKTOP2
Unhingd PigFeedng Gangstr
BRICKTOP2's Avatar
32 is fine on the road (I also run 30) but 25 offroad really isn't doing you much good. Somewhere in the 10-15 range would be a lot more effective.
"Tightening the nut behind the wheel is the most cost effective way to improve the performance of any vehicle."
JK Build Thread http://www.jeepforum.com/forum/f96/3...-build-545214/
TJ Tub Trailerhttp://www.jeepforum.com/forum/f104/...tj-tub-568873/
BRICKTOP2 is offline   Reply With Quote Quick reply to this message
Unread 08-25-2008, 12:06 PM   #5
jmelgin
I've been running at 35 psi but plan to "experiment" with lower pressure.
[B]'08 JK Wrangler X[/B] - Jeep Green, Dual Tops, 5.7L Hemi, 6-spd, 3" Black Diamond lift, 35x12.50 BFG Mud Terrain KM2's, ProComp 1079's.
[B]'08 WK Grand Cherokee Overland CRD[/B] - Steel Blue
[B]'05 KJ Liberty[/B] - Black
jmelgin is offline   Reply With Quote Quick reply to this message
Unread 08-25-2008, 06:25 PM   #6
BiGEN
i dont know if 10 - 15 would be ok on the stock rubi rim... i might try 20 next time.
FOR SALE!
VAJeepTrailDogs
[/color]
Unread 08-25-2008, 06:32 PM   #7
chuck45
I have a 4dr and run 28 on the highway and 15 off road (when I air down - oft times I don't depending on the terrain).
08 JK Unlimited Rubi, Auto, 5.13 gears, RE 3.5" SF lift w Bilstin shocks, BFG 35" KM2's, AEV Pintlers, Alloy USA CM front axles w CTM Ujoints, Superior CM rear axles, JE Reel 1350 driveshafts, RockHard Front Bumper w Warn PP w 3/8 syn rope, RockHard rear bumper and tire carrier, RockHard rocker guards and skid plates, ARB diff covers, ORE C gussets and LCA skids, Tuffy Drawer, Cobra 75, Cibie headlights, Hella 4000 Rally lights, 60" HiLift, PullPal winch anchor, Engle 45 Fridge.
chuck45 is offline   Reply With Quote Quick reply to this message
