-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Tire Carrier needed for stock size Rubicon Spare? (http://www.jeepforum.com/forum/f96/tire-carrier-needed-stock-size-rubicon-spare-1978050/)
krazymatt 01-09-2014 04:25 PM
I'm planning on getting some front and rear bumpers for my 2014 Rubicon soon. I am planning on keeping the jeep pretty much stock as far as tire size. I will likely install a 1 3/4" leveling block up front. If and it's a big if I was to get bigger tires when these wear out I would go with the same width but go with a 33 instead of a 32 or just one size up. I'm kind of reluctant at the idea because of power loss but shall I bother with a rear tire carrier for the aftermarket bumper I go with or just not bother considering there is a good likelihood it will remain stock??? Thanks....
RockyClymer 01-09-2014 04:30 PM
If all you plan is a 33 inch in the future, I think the stock carrier will work fine. If you off road a lot, then the stock carrier on a 35 can be troublesome if the tire is not mounted securely and kept from bouncing and putting additional strain on the carrier. I have seen a couple fail, but many just use the stock carrier and some wheel snubbers like those from Daystar. One forum member even put a large bolt in the bumper spaced just to carry some of the additional tire load...original and simple solution.
krazymatt 01-09-2014 04:51 PM
I'm looking at the Warn Elite series bumpers. In the unlikely event that I did decide to go with say 35s I could always just add the tire carrier portion.
Butterjeep 01-09-2014 04:53 PM
I have a 33 on the stock carrier with no problems.
ROCKR8R 01-09-2014 04:59 PM
You could even get something like this to ease your mind. http://www.amazon.com/Smittybilt-274.../dp/B003EOVHKG
It says up to 37" tire, doubt it, but a 33 would be fine.
-Dan
The time now is 06:14 AM.
