TIPM Recall and Wipers? - JeepForum.com
post #1 of 12 Old 12-01-2008, 02:54 PM Thread Starter
tebone77
Last week the wipers on our '07 Wrangler refused to go off. My husband has to pull the fuse to get them off and then put it in if he needs them on.
We took it in today for the G40 recall (never got anything on the G25 TIPM), asked them to check the wipers.
The dealership called and said the entire TIPM needs to be replaced for $612!
Does anyone have any idea what is going on? If the whole thing is bad, why are the wipers the only thing being affected? Is it possible that something else is going on?
Is there a cheaper fix than having the dealership take care of it?
HELP!!
tebone77 is offline
post #2 of 12 Old 12-01-2008, 02:57 PM
WVUJeeper
Shouldn't this be a warranty issue if you bought it new? Perhaps the dealership needs to be coerced into doing the work.
- Fletcher: Oil Field Trash Extraordinaire
Originally Posted by VetteDriver View Post
BTW, what's with the "if you haven't driven one shut up" nonsense? How can we have a good internet fight if experience and knowledge are going to be a requirement?
'08 Rescue Green Unlimited X - Hard Top, 3.73 gears, Limited Slip, Infinity 7 speaker system, KC Slimlite Long Range, Cobra CB, Rough Country 2.5" BB, 35" BFG KM2's on ProComp 7089's. Fenderless and proud!
My build thread:
RESCUE GREEN JEEP CLUB MEMBER #25
COLORADO JEEP CLUB MEMBER # 1001
WVUJeeper is offline
post #3 of 12 Old 12-01-2008, 03:04 PM
Warlord2
wow, I wouldnt pay a dime, that is a warranty issue.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #4 of 12 Old 12-01-2008, 03:09 PM Thread Starter
tebone77
sorry--I should have mentioned that it is out of warranty already
tebone77 is offline
post #5 of 12 Old 12-01-2008, 03:17 PM
Warlord2
damn that sux, before I pay that kind of cash I would get a second opinion atleast. If the wipers are the only thing being effect I would just put a switch on the wiper fuse (no joke) and run the switch inside the cab to make it easier then having a swap the fuse every time it rains. How is the warrany gone already? did you buy it used or does it just have a lot of miles on it already?
Warlord2 is offline
post #6 of 12 Old 12-01-2008, 03:19 PM Thread Starter
tebone77
a lot of miles...highway miles, but plenty of them b/c of a long commute.
tebone77 is offline
post #7 of 12 Old 12-01-2008, 04:11 PM
SilvRSpeedX3
i had to have the same thing replaced on mine about a month or 2 ago, wipers would go but no dash lights not running, signal, or break lights and the sensor to unlock the shifter was out so i couldnt pull it out of park
2k2 Liberty limited
SilvRSpeedX3 is offline
post #8 of 12 Old 12-01-2008, 04:25 PM
08BlueSahara
What's a TIPM, where to find recalls/TSBs
I was wondering what TIPM (totally integrated power module) meant and where to find recalls and TSBs.
http://project-jk.com/jeep-jk-tsb-recalls
In case anyone else had the same question.
08BlueSahara is offline
post #9 of 12 Old 12-01-2008, 05:13 PM Thread Starter
tebone77
now we picked it up from the dealership and the wipers aren't working AT ALL!! grrrr.....
tebone77 is offline
post #10 of 12 Old 07-09-2013, 08:10 PM
Rickyrab
1978 CJ7
2008 wrangler
Had typical problem with TIPM. Wipers and washer went nuts, just as everyone describes. Ordered TIPM thru Amazon.com for $228.00 including 2 day shipping. Removed old one and installed new one in about 10 minutes. Turned switch on for 20 secnd learn mode, then turned it off for 30 seconds.
Engine cranked up and everything worked perfect with no dealer programming.
Thanks to everyone for their input.
Rickyrab is offline
post #11 of 12 Old 07-09-2013, 09:25 PM
djm
another reason I was comfortable buying the lifetime warranty
djm is offline
post #12 of 12 Old 07-10-2013, 05:28 AM
Rickyrab
1978 CJ7
TIPM Question
Has anyone had to replace the TIPM more than once or does the aftermarket part fix the problem once and for all?
Rickyrab is offline
Possessed Jeep.....TIPM issue?? Lights, horn wipers, etc.... Busa196 JK Wrangler Technical Forum 40 12-31-2015 06:01 AM
Update on TIPM issue tebone77 JK Wrangler Technical Forum 5 01-05-2012 07:52 AM
G40 Recall Sahara GT JK Wrangler Technical Forum 13 06-18-2009 11:07 AM
E22 recall catalytic converter recall???? joedirt88 TJ Wrangler Technical Forum 4 04-04-2007 10:37 AM
'06 recall #F22 ? rockhi TJ Wrangler Technical Forum 17 08-15-2006 07:02 PM
