TIPM Module - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > TIPM Module
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 03-19-2014, 09:07 PM   #1
DEnd73
TIPM Module
2007 Wrangler X (JK) My drivers side taillight and front running lights aren't working. I figured it was grounded out somewhere. Couldn't find it anywhere. So while I had it in the dealership I had them check it out. They told me the TIPM Module was bad that it had a dead wire in it. This is the only problem I have. They say it's $577 for a new one plus $150 to install and program. Is there anyway around this? Can I wire over from the passenger side and make the lights work or is replacing the TIPM my only option? Thanks.
DEnd73 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2014, 06:20 AM   #2
Mlarv
2014 JK Wrangler
There was thread on this the other day. Here is a link to it.
http://www.jeepforum.com/forum/f96/a...e-box-2227249/
As for running a wire around the bad section I would have to see where the bad section where there is a will there is a way.
What Would Scooby Do?
Mlarv is offline   Reply With Quote Quick reply to this message
