tinted half doors for 4 door - JeepForum.com
post #1 of 4 Old 08-20-2010, 09:24 PM Thread Starter
ziggy-the-yj
2010 JK Wrangler
ok, so i have a 4 door with half doors and a soft top. i found a tinted window kit for it, but it only tinted the rear quarter windows and rear windows. im looking for the hlf door window tinted also. at least the rear set of half door windows, but it the have the front ones thats cool too.
doors? what are those for?
ziggy-the-yj is offline
post #2 of 4 Old 08-21-2010, 12:04 AM
tavic
2010 JK Wrangler
Before I had lost my TJ, I had searched for a replacement top with tinted half door windows, but I was never sucessful. In fact I found a few brands that appeared to be tinted in the ads, but they weren't. There has been TJ owners who were sucessful with locating them through Ebay, so you may want to check there.
My '10 Wrangler has the clear rear and side windows and I really wish they were tinted to match the tinted full door windows, but I can't justify with myself to drop the dough for a replacement kit since these windows are perfectly ok. If you search forum, you can find several threads where a "Static Cling" tint has been utlized in the past, but you do run the risk of damaging the tint rather easily when zipping the windows up and down.
I've been toying with the idea of utilizing a black wood stain, clothing dye or food dye since the plastic windows consist of a rather soft plastic. But, I would perfer to test the method on a sacrifical window prior to attempting the process on mine, because the stain/dye may "eat" the plastic. I do remember spotting a few convertibles with plastic windows at the local wrecking yard, so I may stop by to cut me out a test window.
tavic is offline
post #3 of 4 Old 08-23-2010, 02:32 PM
99TJSport
99TJSport's Avatar
I used the static cling tint on my rear upper halves and it's been great. They've been through 2 summers of use now, and look just as good as when it was installed. I was going to buy new ones through the dealer, but they're about $250 ea, and this only cost me about $20, and an hour or so of time. Now it might help that I only run the half doors in the summer, but I'd certainly recommend it as a reasonable solution on the cheap.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #4 of 4 Old 08-23-2010, 02:38 PM
JLC08JK
What was I thinking?
JLC08JK's Avatar
You could go to a shop that makes boat covers and have them replace the windows.
Jim
JLC08JK is offline
Half Door Tinted Windows For Soft Top rio jeep YJ Wrangler Technical Forum 5 02-03-2010 03:26 PM
Tinted half door windows smcurry83 TJ Wrangler Technical Forum 16 03-13-2008 05:42 AM
Tinted Half Doors stedwest TJ Wrangler Technical Forum 12 02-13-2007 01:14 PM
YJ tinted front windows for half doors kevin564 YJ Wrangler Technical Forum 3 08-08-2006 08:44 PM
Has anyone tinted their half door windows bullstuff TJ Wrangler Technical Forum 12 07-12-2006 03:23 PM
