tilting jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > tilting jeep
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep seats at Jeephut.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 02-16-2015, 09:55 AM   #1
FROZEN_INUK
tilting jeep
i thought it was just the way i parked but i've been getting asked this alot lately, is anybody else's jeep looking like it's dipping to one side? for me it seems my front right is down lower then the rest
FROZEN_INUK is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 09:58 AM   #2
rich6700
Factory lean. They all sit an inch lower on the right. Why? Don't know.
rich6700 is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 10:03 AM   #3
ronjenx
ronjenx's Avatar
Not all. Mine doesn't.
2008 JKU Rubicon
42RLE Auto
ronjenx is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 10:10 AM   #4
1slosvt
No gangsta lean here either. Did you buy it new? Has it ever been in an accident?
-2012 JKUS
-2014 GC Laredo
-2k xj
1slosvt is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 10:30 AM   #5
JeepCACares
FROZEN_INUK,
Sometimes it can be something very simple. Have you checked the tire pressure on the right side?
Dave P.
Top Care Specialist
FCA Canada
JeepCACares is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 11:49 AM   #6
Moezer
2015 JK Wrangler
The way the jk is and having the gastank to the right if the jeep its not disterbuted rught in weight wise
Moezer is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 12:00 PM   #7
222Doc
222Doc's Avatar
check the spring isolation rubber
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is offline   Reply With Quote Quick reply to this message
Unread 02-16-2015, 12:18 PM   #8
ronjenx
ronjenx's Avatar
Can you clarify?
2008 JKU Rubicon
42RLE Auto
Unread 02-16-2015, 05:14 PM   #9
wilgeno
Bug-Out!
wilgeno's Avatar
You're joking right? I've never seen a lean to one side or another.
TeraFlexed '13 Commando Green JKU Black Hardtop roll'n on 35's!
Bug-Out! http://www.jeepforum.com/forum/f96/b...build-1568531/
I don't always go topless, but when I do I go Commando!
wilgeno is online now   Reply With Quote Quick reply to this message
Unread 02-16-2015, 06:53 PM   #10
Moezer
2015 JK Wrangler
Originally Posted by ronjenx View Post
Can you clarify?
What I mean is since the gas tank is so damn big and its on the right side of the jeep, when u fill ur gas tank full that's a lot of added gas weight to the right of the jeep, Making it unbalanced and thus making it lean to the right
while on the left side of the jeep there is nothing but the exhaust line that has no weight compared to the gas tank
Also since we lift the jeep that kinda becomes more top heavy causing the jeep To lean more and be more noticeable to the trained eye an average Joe will not catch the lean on a stock Jk
Unread 02-16-2015, 06:59 PM   #11
ronjenx
ronjenx's Avatar
The gas tank can't be a factor, though, if not all JKs lean to the right.
When I weighed my stock JK, with 1/2 tank of gas, no one inside, the right side weighed the same as the left side, indicating equal weight distribution from side to side. The tank isn't all that far from the center line.
2008 JKU Rubicon
42RLE Auto
Unread 02-16-2015, 07:07 PM   #12
Moezer
2015 JK Wrangler
Have u taken out a gas 3/4 full gas tank out of a Jk before? The skid plate holds the gas tank in place its heavy as heck I'm not sure how u weighted ur jeep but I can 100℅ say that the tank with skid will effect the balance of the jeep and its not 50/50 weight
Unread 02-16-2015, 07:13 PM   #13
ronjenx
ronjenx's Avatar
I actually saw the scales, (one under each tire), and rotated them to make sure. It was 50/50. What that says is, whatever the 1/2 full tank weighs, there is something on the other side of the center line to counter it.
If it were the tank, all JKs would lean to the right, which isn't the case.
A lot of people who have had non-leaning JKs, have had them lean after installing lifts or just spacers. Something else must be going on.
BTW, the forward/aft weight distribution was 52%/48%.
2008 JKU Rubicon
42RLE Auto
Unread 02-16-2015, 07:23 PM   #14
Moezer
2015 JK Wrangler
Um not sure where the weight might be on the left side of the jeep haha mine leans about an inch or so to the right u have seen jeep leaning a lot like major, some guys just add a 1/4 or 3/4 inch spacer to the rear right of the jeep but i m not sire how well that would effect the jeeps ride
Unread 02-16-2015, 07:26 PM   #15
JTPhoto
JTPhoto's Avatar
We have 2 JK and a JKU no lean on any of them.
^^Jeff^^
2008 Black and Khaki Sahara Unlimited Trax-Lok rear diff. 3.5" Rock Krawler fr springs, rear TeraFlex 2.5 BB, 37x12.50x17 Pitbull Rockers on ProComp 7069 Alloys, AEV Prem Bumper ETC..
JTPhoto is offline   Reply With Quote Quick reply to this message
