Tie rod and draglink pics needed - JeepForum.com
post #1 of 17 Old 02-19-2013, 10:40 AM Thread Starter
wardo
2011 JK Wrangler
Hey guys,
I'm in the process of replacing my draglink and possibly my tie rod. I was hoping anyone who has an aftermarket draglink or tierod or both could post up some pics of what you've got.
If you have fabbed it up yourself, that would also be awesome to post up.
Thanks a lot.
2011 Flame Red 2dr Wrangler Rubicon, Poison Spyder Evap Skid, Extended Breatherlines, 4' Firefly Antenna, Uniden Pro520xl, Rock Krawler 2.5 Stock Mod Lift, Bilstein 5100's, Rugged Ridge XHD Front Bumper, Warn M8000, Rugged Ridge XHD Snorkel
wardo is offline
post #2 of 17 Old 02-19-2013, 12:51 PM
DBA2GO
So, I have a TeraFlex frame brace & drag link flipped kit, I removed the dropped Pittman arm & replaced it with a a stock arm.
Here is that setup on the driver's side:
Passenger side:
Pic of frame brace on passenger side:
You can kind of see the Poly Performance Synergy tie rod too.
One foot in the grave & one foot on the gas pedal!!
DBA2GO is offline
post #3 of 17 Old 02-20-2013, 05:52 PM
thedirtman
thedirtman's Avatar
I have the currie and would not recommend them at all. Running 4" of lift with flipped drag link. If you can cut and weld ruff stuff has kits you can do your own and save quite a bit.
If you learned something new today, you had a good day.
thedirtman is offline
post #4 of 17 Old 02-21-2013, 10:02 AM
tslewisz
2010 JK Wrangler
Rock Krawler 7075 aluminum tie rod, Fox SS on Synergy mount, stock draglink.
tslewisz is offline
post #5 of 17 Old 02-21-2013, 02:32 PM
SoK66
2009 JK Wrangler
Teraflex frame side drop & brace, reid knuckles, Poly drag link, tie rod & steering damper brackets.
SoK66 is offline
post #6 of 17 Old 02-21-2013, 10:34 PM
BigBlue7
2010 JK Wrangler
Originally Posted by wardo
Hey guys,
Thanks a lot.
I'm in the same boat. Kinda considering ried knuckles, since I'd also like better braking power, and they allow larger brakes.
Rock Krawler | TeraFlex | Synergy | Fox | Poison Spyder | Genright | Nemesis |Beer
BigBlue7 is offline
post #7 of 17 Old 02-21-2013, 10:45 PM
ChuckMRN
2011 JK Wrangler
All Poly here, with Reids
ChuckMRN is offline
post #8 of 17 Old 02-21-2013, 10:54 PM
BigBlue7
2010 JK Wrangler
Poly seems to be the best in my research. They have a lot of steering upgrades that are all compatible with each other.
BigBlue7 is offline
post #9 of 17 Old 03-02-2013, 01:28 PM Thread Starter
wardo
2011 JK Wrangler
I don't think my Rk 2.5stock mod lift requires a flipped draglink and tierod. Had a couple of episodes of dw so I know several of my components need to be replaced.
wardo is offline
post #10 of 17 Old 03-02-2013, 04:18 PM
Butterbuddha
2010 JK Wrangler
It probably doesn't require it, but it sure is nice to have!
YOU CAN'T HANDLE THE TRUTH!
Butterbuddha is offline
post #11 of 17 Old 03-02-2013, 04:22 PM
thedirtman
thedirtman's Avatar
You should not be doing a drag link flip until 3.5"+ of lift and only if you are having bump steer, doing a drag link flip will limit your up travel and may require extended bump stops.
post #12 of 17 Old 03-02-2013, 05:36 PM
Prot
Prot's Avatar
2014 JK Wrangler
PolyPerformance high steer kit along with a PolyPerformance chromoly tie rod will improve steering dramatically with lifts 3" and higher.
Regardless if you have any lift or stock, the PolyPerformance chromoly tie rod is a big improvement over the crappy stock one.
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #13 of 17 Old 03-02-2013, 05:50 PM
brianjw
Synergy tie rod, synergy track bar, synergy frame side track bar/sector shaft brace, synergy ball joints, AEV drag link end and axle side track bar bracket.
I think the synergy drag link will be the next part up front if I figure out that it will work with the pintler wheels.
brianjw is offline
post #14 of 17 Old 03-02-2013, 09:52 PM
TxRubiGrl
Im soo very jealous of all of ya'll that live in a rust free area. All of ya'lls underbelly and suspension parts look spotless.. (sorry for interupting the thread)
2006 Rubicon stolen 20Jun2010 :(
http://i14.photobucket.com/albums/a311/sageser9/IMAG0144.jpg
United States Coast Guard
TxRubiGrl is offline
post #15 of 17 Old 03-03-2013, 07:42 AM Thread Starter
wardo
2011 JK Wrangler
Ya mine doesn't look at all like that LOL.
wardo is offline
drag link , fab , pic's , suspension , Tie rod end
