-   JK Wrangler Technical Forum (http://www.jeepforum.com/forum/f96/)
-   -   Tie rod and draglink pics needed (http://www.jeepforum.com/forum/f96/tie-rod-draglink-pics-needed-1481261/)
wardo 02-19-2013 09:40 AM
Hey guys,
I'm in the process of replacing my draglink and possibly my tie rod. I was hoping anyone who has an aftermarket draglink or tierod or both could post up some pics of what you've got.
If you have fabbed it up yourself, that would also be awesome to post up.
Thanks a lot.
DBA2GO 02-19-2013 11:51 AM
So, I have a TeraFlex frame brace & drag link flipped kit, I removed the dropped Pittman arm & replaced it with a a stock arm.
Here is that setup on the driver's side:
https://lh4.googleusercontent.com/-I...0/DSCN0489.JPG
Passenger side:
https://lh5.googleusercontent.com/-P...0/DSCN0490.JPG
Pic of frame brace on passenger side:
https://lh6.googleusercontent.com/-A...0/DSCN0491.JPG
You can kind of see the Poly Performance Synergy tie rod too.
thedirtman 02-20-2013 04:52 PM
2 Attachment(s)
I have the currie and would not recommend them at all. Running 4" of lift with flipped drag link. If you can cut and weld ruff stuff has kits you can do your own and save quite a bit.
tslewisz 02-21-2013 09:02 AM
Rock Krawler 7075 aluminum tie rod, Fox SS on Synergy mount, stock draglink.
http://tslewisz.smugmug.com/Vacation...IMG_2094-M.jpg
SoK66 02-21-2013 01:32 PM
Teraflex frame side drop & brace, reid knuckles, Poly drag link, tie rod & steering damper brackets.
http://i160.photobucket.com/albums/t...kles/Reid1.jpg
BigBlue7 02-21-2013 09:34 PM
Originally Posted by wardo
Hey guys,
Thanks a lot.
I'm in the same boat. Kinda considering ried knuckles, since I'd also like better braking power, and they allow larger brakes.
ChuckMRN 02-21-2013 09:45 PM
All Poly here, with Reids
http://im1.shutterfly.com/media/47a3...D550/ry%3D400/
BigBlue7 02-21-2013 09:54 PM
Poly seems to be the best in my research. They have a lot of steering upgrades that are all compatible with each other.
wardo 03-02-2013 12:28 PM
I don't think my Rk 2.5stock mod lift requires a flipped draglink and tierod. Had a couple of episodes of dw so I know several of my components need to be replaced.
Butterbuddha 03-02-2013 03:18 PM
It probably doesn't require it, but it sure is nice to have!
thedirtman 03-02-2013 03:22 PM
You should not be doing a drag link flip until 3.5"+ of lift and only if you are having bump steer, doing a drag link flip will limit your up travel and may require extended bump stops.
Prot 03-02-2013 04:36 PM
PolyPerformance high steer kit along with a PolyPerformance chromoly tie rod will improve steering dramatically with lifts 3" and higher.
Regardless if you have any lift or stock, the PolyPerformance chromoly tie rod is a big improvement over the crappy stock one.
brianjw 03-02-2013 04:50 PM
Synergy tie rod, synergy track bar, synergy frame side track bar/sector shaft brace, synergy ball joints, AEV drag link end and axle side track bar bracket.
I think the synergy drag link will be the next part up front if I figure out that it will work with the pintler wheels.
http://i462.photobucket.com/albums/q...ir/null-25.jpg
http://i462.photobucket.com/albums/q...ir/null-23.jpg
TxRubiGrl 03-02-2013 08:52 PM
Im soo very jealous of all of ya'll that live in a rust free area. All of ya'lls underbelly and suspension parts look spotless.. (sorry for interupting the thread)
wardo 03-03-2013 06:42 AM
Ya mine doesn't look at all like that LOL.
The time now is 12:02 AM.
