This thud is driving me crazy! - JeepForum.com
post #1 of 14 Old 07-21-2015, 05:03 PM Thread Starter
Lyoungman
I have a 2012 Wrangler sport unlimited. On windy days there is a thud under my front wheel wells. At first I thought it was my after marker mud flaps, I removed them. And still today thud. Im always going straight at at high speeds 55/70. Has anyone experienced this. Im thinking its my wheel well liners, they are flimsy and dont appear to be attached well. Anyone else have this issue, or am I losing my mind!!! The dealership has looked in the past, all looked well.
Hoping for a cheap fix, suggestions are welcome.
Lyoungman is offline
post #2 of 14 Old 07-21-2015, 05:11 PM
Jeff88
I searched around for a thud on our 2013 Rubicon that was making me crazy. I could not pin point where it was it sounded like it came from so many different places.
I finally found out it was the tailgate latch wasn't grabbing the retaining rod tightly and it would make a thud due to the slack whenever I took off, or slowed down or at other random times.
I had the girlfriend drive me around and do different driving maneuvers in a parking lot as I sat in all the other seats, including stuffing myself (I am 6'5 275) in the way back which is where I finally heard it.
Not saying it is what you have, but could be.
Jeff88 is offline
post #3 of 14 Old 07-22-2015, 05:36 AM
mello
Originally Posted by Lyoungman
I have a 2012 Wrangler sport unlimited. On windy days there is a thud under my front wheel wells. At first I thought it was my after marker mud flaps, I removed them. And still today thud. Im always going straight at at high speeds 55/70. Has anyone experienced this. Im thinking its my wheel well liners, they are flimsy and dont appear to be attached well. Anyone else have this issue, or am I losing my mind!!! The dealership has looked in the past, all looked well. Hoping for a cheap fix, suggestions are welcome.
The inner fender liner is probably flapping against body mine was doing exact same thing on windy days. Put some double sided foam tape behind fender liner where it contacts body and see if noise goes away.
mello is offline
post #4 of 14 Old 07-22-2015, 07:41 AM
yllwjckt07
May not be related at all but I put on a bestop trektop nx a week ago and had the top open when driving on the highway last weekend. All of my passengers and I felt a "clunk" coming from under the vehicle. It was really making me concerned. I stopped on side of road and looked under vehicle. Everything looked ok. Got going again and the clunk remained. Something dawned on me that the only thing I had done recently was install the top. I closed the top and the clink was gone. It was resonating through the roll bars to the underside of the vehicle. Not sure if this could be what you are experiencing but worth a shot.
yllwjckt07 is offline
post #5 of 14 Old 07-22-2015, 12:02 PM
motoguy1251
My hood jumps up in the wind, and when it comes down its got a thud to it.
motoguy1251 is offline
post #6 of 14 Old 07-23-2015, 09:22 AM Thread Starter
Lyoungman
Thanks all, Im hoping mellow is right. My brother in law is going to design something to stop the inner wheel well liner from moving. Im hoping that is my fix!
post #7 of 14 Old 09-15-2015, 11:59 AM
JDubbya
Lyoungman, if you do have the trektop nx, you might want to consider what yllwjckt07 is suggesting. I had the same exact issue, it took me a bit, but I realized it was just that, the soft top flap bumping. The banging sound resonates and sounds as if its coming from below. If I am on the highway and want the top open, I bungee it down.
JDubbya is offline
post #8 of 14 Old 09-15-2015, 12:07 PM
JIMBOX
I have retaining screws in my fender liners--you don't have any ???
Mine don't move at all !
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #9 of 14 Old 09-15-2015, 01:13 PM
222Doc
222Doc's Avatar
sounds like the hood. THe stock rubber just dont do enough. If you removed the front lower air dam, that makes more air get under the hood.
222Doc is offline
post #10 of 14 Old 09-15-2015, 02:44 PM
DV8Offroad
If it is your inner fender liners you should be able to just do as mello said and put some double sided tape back there. If you have cut or aftermarket fenders you may have to figure out another solution. Our inner fenders were designed to help solve this kind of problem.
https://www.dv8offroad.com/fenders---liners.html
DV8Offroad is offline
post #11 of 14 Old 09-16-2015, 12:13 PM Thread Starter
Lyoungman
It only happens when the tops is off and yes it's a best top I installed in the beginning of summer. I don't think it's the bars on top tho. The thud comes from underneath by my feet. I have secured the inner wheel wells but it still happens on a windy day.
post #12 of 14 Old 09-16-2015, 01:03 PM
DV8Offroad
Is the noise when you hit bumps to where it could be a suspension issue? Does it thud once then stop or continuous thumping?
post #13 of 14 Old 09-17-2015, 04:03 PM Thread Starter
Lyoungman
It's when driving and windy.. Flat roads..
post #14 of 14 Old 09-17-2015, 06:21 PM
JohnRodriguez
it's the back of your inner fenders, specifically the rear. if you get some body push anchors, the same as used truout your jeep, you can put a couple of them on the rear of the fender and It will take care of the flapping noise. I had attached my fenders to plug on the end of the rubicon rails I have installed on jeep. I've had my JK well over the speedo reading and it has no more noise.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
