Depress the pedal before you think you need to. Let us know how many milliseconds you need to do the early launch at the next stop light you come to. I'm sure it will make the whole driving experience much better.:2thumbsup:
When I got my 08 JK the dealer told me about this and that after a few hundred miles the ECU would "learn" my driving style on the throttle - low and behold it apparently did because after about 200 or so miles the issue went away and works great now - how many miles on it?
I have no delay in my throttle but if there is, it is cleverly masked by an under powered non responsive engine. Maybe you need to bring yours in for a check up.
My comment about pressing the throttle before you think you need to was a sarcastic attempt at humor. To eliminate throttle lag press early, get it?
I find if I need to take off in a hurry, I will get better results if I press the pedal instead of stomping it. I know that sounds weird, but doing it this way is a faster launch and there is no delay. If I stomp it, there is enough of a delay that is annoying. Try it before you laugh at me.
I would assume they ramp the throttle blade open to increase fuel economy instead of just going WOT. It gives the computer complete control of air delivery to the engine.
The computer is just giving you a chance to rethink what you are about to do - since everyone is always complaining about gas mileage, this "feature" gives you a pause to consider a more even-handed driving approach and save on gas, thus sparing the rest of us another "Help, my gas mileage is horrible. Will a Vornado help?!" thread.
yet to see any throttle delay on mine and can even put down rubber if I wanted to. Just curious if all you people that are having problem have a automatic? or if its been a problem with manuals too.
I had a camaro with the ET. I NEVER had the weird-ness I have with the jeep. I thought it was the traction control kicking in. But it did the same thing after I turned it off.
Like said before, if you go easy, its fine. But when I try to row through the gears it gets annoying.
Part of the reason I submitted the question is that my 08 JK sometimes will stall and die. A combination of not being to hear the motor rev, no real vibrations from the engine revving, and the delay of the rev sometimes I bog the engine down when I let off the clutch before the engine has time to rev enough to pull itself.
Does anyone know if any of the mentioned modifications void the warranty? Such as programming, cold air intake, cat back exhaust, and so on.
I did this a lot with mine in the first 1000 miles. I always owned vehicles with noisy engines. The JK is just plain quiet. But I never attributed that to throttle lag, only driver error. Once I learned how the engine felt through the stick and clutch, it wasnt a problem anymore.
For me, it only seems the lag comes in to play after the clutch is let out.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
