Throttle Body spacer - Page 2 - JeepForum.com
post #16 of 25 Old 06-15-2010, 09:10 PM
daggo66
2009 JK Wrangler
Not many people are willing to spend $300 and then post on a forum that it didn't work. Wanting to feel a difference can trick you into thinking there was one. If there really increased power and MPG why would they not be standard equipment with all the pressure dealers are under due to government regulations?
Tom
daggo66 is offline
post #17 of 25 Old 06-15-2010, 09:17 PM
tjkj2002
2002 KJ Liberty
Throttle body spacers only work on TBI engines,and there close cousin the carb spacer(where they got the idea) only works on carb engines.
The above are both "wet" intakes and benefit from the added length in the intake which gives the fuel/air going through more time to mix and atomize(fuel).In a multiport FI engine like what the 3.8 uses that spacer will do nothing as you have a "dry" intake with only air running through the intake,no benefit at all.
tjkj2002 is offline
post #18 of 25 Old 06-16-2010, 04:01 AM
PASKS
More plenum volume is more plenum volume. No matter how you look at it or where you get it.
PASKS is offline
post #19 of 25 Old 06-16-2010, 07:24 AM
yukonmuscle
2009 JK Wrangler
thats right. the only thing a spacer will do in a dry intake is increase the volume of air the intake can hold, not sure if it would increase power but may improve throttle responce as more air would be available as the throttle is being opened
so much sunshine, the jeep gods are smiling at me
yukonmuscle is offline
post #20 of 25 Old 06-16-2010, 07:34 AM
N2rock
N2rock's Avatar
I too would like to see dyno proof before spending that kind of money. And I have yet to see any dyno proof. In fact the dyno records I've seen showed zero increase, and even a decrease in one.
As far as the TB changing the shifting- not gonna happen. Drive by wire system with the shifting controlled by the computer. There's just no way a TB would make the computer behave differently where the shifting is concerned. You need something that can change the program, IE: Flashpaq
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #21 of 25 Old 06-16-2010, 07:38 AM
djkbooth
2010 JK Wrangler
I had a buddy that had one on his man. tranny jk ...a power aid brand the red model one, he didnt feel a difference so he gave it to me to try, I have been running it on my auto since, it made a difference on pick up at low end but I cant tell any difference on high end, so my vote is yes for the autos!
djkbooth is offline
post #22 of 25 Old 06-16-2010, 11:06 AM
2005X
that my friend is what you call BUTT DYNO! beleive me when i got my flowmasters on my new truck i thought i felt the pwer difference in reality there was none. its amazing what your mind tells you when you spend money on crap to make yourself feel better.
2005X is offline
post #23 of 25 Old 06-16-2010, 12:24 PM
ncb
Nice, be nice and quit acting like a couple tards.
ncb is online now
post #24 of 25 Old 06-16-2010, 12:42 PM
2005X
but daddy he started it
2005X is offline
post #25 of 25 Old 06-16-2010, 01:59 PM
ncb
I stacked 12 TB spacers together and gained 300 hp. Who needs a hemi?
ncb is online now
TJ 2.4 throttle body spacer DiegoTJ TJ Wrangler Technical Forum 5 08-11-2013 08:41 PM
Which Throttle Body Spacer for YJ LST022752 YJ Wrangler Technical Forum 18 12-08-2009 07:46 AM
throttle body spacer linkage bracket spacer ? kmo0189 YJ Wrangler Technical Forum 3 09-24-2006 10:42 AM
Throttle Body Spacer Jeepdrivinmid TJ Wrangler Technical Forum 31 12-11-2005 08:20 AM
THROTTLE BODY SPACER beepbeep TJ Wrangler Technical Forum 2 01-19-2002 05:28 AM
