Thoughts on this suspension setup! - JeepForum.com
post #1 of 6 Old 01-07-2014, 09:40 AM Thread Starter
nicholasburr
Hi guys,
I'm definitely a noob when it comes to this, but I think I've figured out a good setup with the help of Nick at Kolak, It goes like this.
OME springs themselves set of four. around 2 inches
The Bilstein 5100 set of four.
these extras:
RE rear trackbar relocation bracket
RE rear extended swaybar endlinks
RE rear brake line relocation brackets
Questions:
will I be able to put a 35 inch tire under this lift for full use of it? no rubbing?
my wheels are 4.25 inch backspacing
Would this be a good ride, same or better than stock?
And what would be the easy of install? I have eh tools. something I need to change
Thanks
Nick
nicholasburr is offline
post #2 of 6 Old 01-07-2014, 01:28 PM
ROCKR8R
Is this a 2 door JK or 4 door? Light duty, medium or heavy duty springs? If I am not mistaken OME lifts give you more than advertised. I think the 2.5" on a 2 door JK gets around 4". Personally I would skip the Rubicon Express parts and get a better brand under there like Synergy or JKS. I would also skip the rear sway bar end links (assuming they are so you can put the stock rears up front) and get some front quick disconnects. I would also get a front adjustable trackbar, cause I am betting you are going to get more than 2" from OME.
-Dan
ROCKR8R is offline
post #3 of 6 Old 01-07-2014, 01:31 PM
ROCKR8R
Oh as for the ride. Bilstein's are little on the firm side for offroad and the OME springs are stiffer to support a loaded rig, depending on if you go with light, med, or heavy duty. Your ride will be a bit stiffer but not terrible.
-Dan
ROCKR8R is offline
post #4 of 6 Old 01-07-2014, 08:41 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I would also suggest skipping the RE parts and investing in an adj front and rear track bar, front disconnects and just using some "fence menders" cut in half to lower the rear brake line. The ride should be very good with the OME and shocks.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #5 of 6 Old 01-08-2014, 07:12 AM
COLOUXJ
2010 JK Wrangler
I have almost the exact same setup as you. If you use the HD springs I netted about 3.5" on a 4 door. I really like the Bilsteins especially since I broke them in.
Did a write up on my build. Some good things to look out for are explained.
JK Lift Install & Suspension Lessons Learned
COLOUXJ is offline
post #6 of 6 Old 01-08-2014, 07:29 AM
GauchoMark
2011 JK Wrangler
here is a link to my build - fairly similar. I have a JKU with quite a bit of steel on it and used the heavy duty OME coils and netted maybe 3" of lift. There are some comparison pics in there.
http://www.jeepforum.com/forum/f96/todays-day-1539422/
GauchoMark is offline
