Those with 3" lifts - JeepForum.com
post #1 of 4 Old 12-01-2010, 09:08 AM Thread Starter
GunDude
2011 JK Wrangler
Those with 3" lifts
Hello, new to this fourm and proud owner of a 2 door 11' JK Sport! I want to put a 2.5" - 3" lift on it. Looking at the BD 3" lift with new coils, adj. track bar, and cam bolts, shocks, brake line extension brackets, etc.
Was wondering if I need to get upper control arms to adj. pinion angle or will the cam bolt be good enough? From what I have gathered, it seems pinion angle is not a concern with lifts up to 3".
Would lower control arms be needed to center the axle?
Thanks for your help! It is good to back in a Jeep. I have owned in the past two CJ5's, wrangler when first came out, commanche, and a cherokee many years ago! My latest was a 95' Bronco with 6" lift and 351, with 4:88's and 35's, that I traded in on my 11' Wrangler.
GunDude is offline
post #2 of 4 Old 12-01-2010, 12:50 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
I know of several who run the BDS lift and it seems to be a good lift and very solid. Couple of points. First, the choice is yours for the caster angle up front - either leave it as is ( some do) cam bolts (which involve knocking out a plug and is hard to reverse if you ever go to adj control arms) or just take the plunge and go with adj control arms up front. In the rear, my opinion is that it would be a good idea to go with adj. control arms and adjust the rear pinion, esp in a 2 door where the drive shaft is shorter. This will lengthen the life of the rear DS Rzeppa joints IMO. Second, the control arms have nothing to do with centering the axle - this comes from a adj track bar (panhard bar in older terms) and IMO will be a must with that much lift to keep the ESP system happy. Fill out your profile and keep us posted. Ohhhhh and welcome to the forum.
Also, a question, why a 3" lift? Looks, off road, big tires or a combination?
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 4 Old 12-01-2010, 05:50 PM
PlatinumOre
I bought the BDS lift off ebay for quite bit off.
Shocks, SStablizer, coil springs, quick, sway bar discos., cam bolts(wont use), bump stop exts, rear sway bar drop brackets, rear track bar relocation bracket
I bought JKS Adj front track bar and JKS front Adj Lower Control arms,
ive heard bad news with using bolts so thats why i personally went with the 400$ control arms. I never read anywhere in my research that the rear will need much of anything done to it, i might be forgetting though.
remember the BDS 3" wont level out your rake... doesn't bother me none, just thought id throw that out there.
PlatinumOre is offline
post #4 of 4 Old 12-02-2010, 04:41 PM Thread Starter
GunDude
2011 JK Wrangler
Thanks for the replies! I am going to get the BDS 3" lift and not use the cam bolts, and upgrade to Bilstien 5100's. I will upgrade front and later the rear lower control arms.
GunDude is offline
All with 5.5" lifts, need help! IH8ROADZ TJ Wrangler Technical Forum 5 10-19-2010 07:41 PM
The "Gray Area" on susp lifts and when an SYE is required, whats your experience? parabs TJ Wrangler Technical Forum 14 07-31-2010 10:50 PM
4" lifts Barrio YJ Wrangler Technical Forum 18 05-25-2008 10:56 PM
"short" long arm lifts? BillR TJ Wrangler Technical Forum 1 05-22-2008 06:41 AM
***lets see PICS of your TJ w/ 3.5"/4" lifts and 35"s STANG KILLA SS TJ Wrangler Technical Forum 48 04-20-2004 10:00 PM
