are there any 07-08 JK's that DON'T have excessive oil use? - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > are there any 07-08 JK's that DON'T have excessive oil use?
Bds fox ipf 2.0 racing series shocks now available at rockThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
View Poll Results: does your 3.8 JK use excessive oil?
yes, more than 2-3 qts between changes 5 18.52%
no, less than 1-2 qts between changes 22 81.48%
Voters: 27. You may not vote on this poll
Unread 01-16-2014, 01:56 PM   #31
blackjeep05
The metered valve inside had some resistance meaning it was wear on the part.
Soccer six in the mix.
blackjeep05 is offline   Reply With Quote Quick reply to this message
Unread 01-17-2014, 01:04 PM   #32
taoshum
run some Sea Foam through it, seems to help some folks.
Geezer from NM
"Wisdom isn't cheap; we pay for it with pain
taoshum is offline   Reply With Quote Quick reply to this message
