terrible clunk and lurch when starting. 2006 auto wrangler unlimited - JeepForum.com
post #1 of 9 Old 12-29-2009, 12:47 PM Thread Starter
jdanilson
My 2006 wrangler unlimited (33K miles) with automatic has just started having a problem. It occurs when starting from a dead stop and accelerating to 1 or 2 mph at which point there is a terrible clunk (metal on metal) sound from the rear and a jerk. Both times I thought I had been rear-ended! It's definitely not the brakes and I'm guessing it's in the differential.
It first occurred on 12/24. It occurred again on 12/27. So only two times but I've been doing lots of driving. Both times were nearly identical. I was stopped at a light and started accelerating. If it makes a difference, I've been doing a lot of 4H driving here due to snow but in both of these situations I was in 2H mode. (I've done some limited off-road driving but none recently; the last time was back in August 2008.)
I'm taking it to the dealer on Thursday (12/31) but hate to go there with an undiagnosed issue.
Thanks in advance for any ideas.
jdanilson is offline
post #2 of 9 Old 12-29-2009, 12:56 PM
99TJSahara
wrong section, you have a tj
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #3 of 9 Old 12-29-2009, 01:03 PM
JeffinWesternWA
2010 JK Wrangler
Sounds like U joints, can be differential (low fluid or other problem), are you sure it's "center" of the rear, not either rear wheel area?
JeffinWesternWA
JeffinWesternWA is offline
post #4 of 9 Old 12-29-2009, 02:03 PM Thread Starter
jdanilson
sorry about posting in the wrong group. should I move it?
As to the question it's hard to tell but I'm reasonably certain it's from the rear and I can't favor either side.
post #5 of 9 Old 12-29-2009, 02:15 PM
1222
RIP John
1222's Avatar
Youíre fine. Itís all related.
When you find out the problem let us know if you happen to go to the TJ section though. At least, Iím curious.
(2011-2016)
1222 is offline
post #6 of 9 Old 12-30-2009, 09:32 AM
calemasters
Do you also det an engine flair? If so, check the auto transmission fluid level. But since you indicated a metal on metal noise, it may be a loose rear axle / suspension link connection or bushing. Also, could be something like a loose or broken transmission mount.
calemasters is offline
post #7 of 9 Old 07-14-2013, 09:26 AM Thread Starter
jdanilson
No update to this since it has not recurred. I had my mechanic check for u joints or differential oil levels. Everything is fine. I guess I just have to wait.
post #8 of 9 Old 07-14-2013, 10:48 AM
jmb6420
Engr. & Mechanic 08 Rubi
jmb6420's Avatar
Dang man, after 3 1/2 years I'd say it is solved.
Mike
08 Rubicon
"You can't fix stupid" Ron White
°ɹǝʌo ǝɯ dıןɟ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
jmb6420 is offline
post #9 of 9 Old 07-15-2013, 03:24 AM
tankinyj
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is online now
Soft Top - 2006 Jeep Wrangler Unlimited chadwick1875 TJ Wrangler Technical Forum 16 05-23-2014 09:38 AM
Lifting a 2006 wrangler unlimited. badjamman TJ Wrangler Technical Forum 5 08-12-2009 07:32 PM
2006 Wrangler Rubicon Unlimited LJ Buying Question (Manual vs. Auto) PHIXIOUS TJ Wrangler Technical Forum 15 07-09-2009 03:12 PM
2006 Wrangler Unlimited Cracked Windshield...HELP! andijeep TJ Wrangler Technical Forum 21 01-05-2009 09:55 AM
Brand new 2006 Wrangler Unlimited ... some questions! thecollector TJ Wrangler Technical Forum 21 12-23-2005 09:46 PM
