TeraFlex SpeedBumps and JK Products Videos - JeepForum.com
post #1 of 4 Old 12-29-2010, 12:43 PM Thread Starter
TeraFlex
TeraFlex is offline
post #2 of 4 Old 12-29-2010, 08:04 PM
kenskis
Are the speedbumps like a dashpot, ie is force proportional to velocity?
|______
|l ,[____],
l---L –OlllllllO-
()_)-()_)--o-)_)
Red 03 TJ sport l OME lift l ARB's front & rear l 4.11 gears l 32X11.50" MTR's l Nth Degree Tummy Tucker l SYE & CV l Nth Degree Dana 44 slider l Nth Degree Oil Pan Skid l JKS adjustable front track bar l KC slimlights l Rock Rails l IPF H4 headlights l Dynamat
kenskis is offline
post #3 of 4 Old 12-29-2010, 11:59 PM
Warlord2
wow I had no idea teraflex even made anti swap bars for the JK. Im glad someone tuned/valved some fox racing shocks and made some bolt on speed bumps for the JK. My bump stops are all bent up from the whoopties on the dunes, I hear they make a world of difference when halling a$$ through the trails. I will be looking for some when I go to coilovers up front.
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #4 of 4 Old 12-30-2010, 09:42 AM Thread Starter
TeraFlex
No they use a special foam inside them. So no worries about seals, leaks, rebuilding just install and go! They start compressing at 50 lbs then ramp up to 4500lbs each when fully compressed.
SpeedBumps make a huge differance when your playing in the whoops and bumpy roads. They can also help prevent the axles from bending by cushioning the blow when you bottom out.
TeraFlex is offline
Speedbumps nocking out fuel pump?? BigOrange90YJ YJ Wrangler Technical Forum 20 02-15-2010 11:50 AM
Instructional Videos Divinitous TJ Wrangler Technical Forum 12 01-04-2008 08:37 PM
Videos Todd35 JK Wrangler Technical Forum 1 10-14-2007 11:16 AM
Do you know where I can see some videos Dan Morera YJ Wrangler Technical Forum 1 01-15-2002 04:08 PM
