Teraflex leveling kit or RC 2.5" - Page 2 - JeepForum.com
post #16 of 28 Old 04-10-2010, 11:14 AM
JLC08JK
What was I thinking?
JLC08JK's Avatar
Originally Posted by Jared89 View Post
Old thread but, on TF site they say you need spaces to run the stock wheels? Anyone know why?
The back-space on the stock wheels is such that the sway-bar links (when extended) can hit the back of the tire.
Spacers are needed to provide the proper clearance.
Jim
JLC08JK is offline
post #17 of 28 Old 04-10-2010, 08:28 PM
Jared89
2011 JK Wrangler
Thanks for the answer.
Jared89 is offline
post #18 of 28 Old 04-10-2010, 11:18 PM
GEM1N1
Go with the 2.5 kit so you don't have to upgrade later if you want to run 33's or 35's. It's only about $50 more than your leveling kit.
2008 2dr Black Rubicon Automatic.
2.5" Rough Country BB
295/70/17 Nitto Trail Grapplers
GEM1N1 is offline
post #19 of 28 Old 04-26-2010, 07:01 PM
plac
Teraflex Leveling Kit
Installed just the front so far. I'll install the back tomorrow. Only using half my front spacers, so I'll prob sell the other new set for a tiny discount or something..
front wasnt too bad, maybe 1.2 hours at most. Tires came off, drivers side was a tad easier to get the spring back in, passenger side took some muscle and I probably will have pulled something by tomorrow with those awkward angles lying on the floor. Did NOT need to undo any brake lines or anything for this tiny lift.
btw, fitment was flawless. the spacers are a lot heavier than they look. Perfect fit, jiggle it a bit to make sure its all centered up. didnt remember the torques for the lower shock mount and sway bar end links so i just did my best guesses.. 80 ft lb on shock bolt, 70 ft lb on end links.. probably too much torque everywhere...
so are the rears easier or harder to install than the fronts, as far as getting the spring out and brake line issues?
2015 Subaru WRX
plac is offline
post #20 of 28 Old 04-26-2010, 08:11 PM
JLC08JK
JLC08JK's Avatar
Here you go, torque specs >Project-JK.com - Jeep JK Wrangler Resource
Hope it helps
Jim
JLC08JK is offline
post #21 of 28 Old 04-26-2010, 09:26 PM
plac
Hope it helps
thanks bro, looks like i got close enough..
let me say right now... THE REAR IS MUCH HARDER!!
dang, after 2 hours alone on the rear i am finally done. looks awesome.. had a real hard time dropping the axle far enough to get the springs out. had to use my spring compressors which in itself was difficult given the space.
2015 Subaru WRX
plac is offline
post #22 of 28 Old 04-26-2010, 09:49 PM
JLC08JK
JLC08JK's Avatar
When I did mine I unbolted the track-bars and sway-bar links.
This way the springs fall right out when you drop the axle.
Make sure you un-bolt the brake line brackets before you drop the rear axle!!!
Jim
JLC08JK is offline
post #23 of 28 Old 04-27-2010, 01:04 AM
lotus03
2009 JK Wrangler
nice pics thanks
http://www.youtube.com/watch?v=95qZtwJNjxk
lotus03 is offline
post #24 of 28 Old 04-27-2010, 01:21 AM
JLC08JK
JLC08JK's Avatar
O.K. sorry about that!!!
No pic's of the actual work but here's a before and after with the RC2" bb.
And one of the extended s/b links I made for the rear before plug welding.
I moved the rears to the front then cut the fronts and made these for the rear.
Jim
JLC08JK is offline
post #25 of 28 Old 04-27-2010, 06:30 AM
plac
good tips. i never unbolted my rear track bar. i was afraid it wouldnt bolt back up properly after the spacers. and i did unbolt the brake lines.. but that wire wrapped in loom seemed to be tighter than the brake lines themselves..
now im asking myself... why did i install this lift? what was the point?
2015 Subaru WRX
plac is offline
post #26 of 28 Old 04-27-2010, 11:05 AM
JLC08JK
JLC08JK's Avatar
I know, it's a lot of work for a little lift!!!
But now you have room for bigger tires
I think of it as a stepping stone to future mod's.
Jim
JLC08JK is offline
post #27 of 28 Old 04-27-2010, 11:25 AM
plac
I don't plan to change tire size either, I might just take it off
2015 Subaru WRX
plac is offline
post #28 of 28 Old 04-27-2010, 04:34 PM
plac
i take that back. it was my user error. rears are probably easier. my tall SUV jack wasnt letting the rear axle drop far enough. i found out when i removed the kit. I did unbolt the brakeline brackets on all 4 corners just for extra safety.
2015 Subaru WRX
plac is offline
Teraflex leveling kit and 34" tires? ncb JK Wrangler Technical Forum 40 04-07-2012 01:41 PM
Leveling after RC 3.25" lift install CTUnlimited TJ Wrangler Technical Forum 5 06-30-2011 06:02 PM
Teraflex Jk Wrangler Leveling kit JKommuter JK Wrangler Technical Forum 14 06-02-2009 03:39 PM
Will 35" tires fir with a leveling kit up front Little Green JK Wrangler Technical Forum 3 02-02-2009 02:40 PM
leveling kit with 3" lift robruin JK Wrangler Technical Forum 0 11-04-2008 04:29 PM
