Teraflex Budget Boost - No Space Between Front Bumpstops??? - Page 3 - JeepForum.com
post #31 of 46 Old 10-09-2013, 04:24 AM
SLADE
Your Pass. Side also has the 16 which is a slightly taller coil spring.
2014 Wrangler JKU
2013 Wrangler JK
2004 Wrangler TJ on LEAFS
2001 Dodge Ram 2500
SLADE is offline
post #32 of 46 Old 10-09-2013, 07:31 AM
duneslider
I am also betting you had this same spacing before you added the spacers and the bumpstop extenders. You just didn't notice because you weren't working on the suspension.
duneslider is offline
post #33 of 46 Old 10-09-2013, 07:46 AM Thread Starter
SoCal_HEMIHead
Yes, I agree... it probably was this way I just never noticed it.
SoCal_HEMIHead is offline
post #34 of 46 Old 10-09-2013, 03:10 PM
D700
2014 JK Wrangler
I have a 2011 JK 2 door with a TF 2.5 BB the space in between is about an inch. No issues here.
D700 is offline
post #35 of 46 Old 10-29-2013, 08:24 AM Thread Starter
SoCal_HEMIHead
Thanks to duneslider I installed a set of Teraflex 2.5" springs up front and that fixed my problem. I now have about 2 inches of clearance at the front bumpstop and the Jeep rides smooth over bumps. I gained an additional 1" of height up front.
So the question is... I now have two new front Teraflex spacers for spare parts. Should I 1) cut them in half and add an additional 1" of height up front? 2) sell them? 3) play hockey?
post #36 of 46 Old 10-29-2013, 08:38 AM
SLADE
Sell Them.
Also, Post pictures of your new setup. Both of the Jeep and of the bump stop.
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #37 of 46 Old 10-30-2013, 10:45 AM
SilverStreaker
Please post some pics when you get a chance. Looks like I will be getting the front springs too.
My Jeep - 2012 Wrangler Unlimited Sport S
My Wife's Jeep - 2007 Grand Cherokee - only mod - K&N Cold Air Intake system
SilverStreaker is offline
post #38 of 46 Old 10-30-2013, 12:40 PM
TOK
How hard were the spacers to pop out? When I heard them seat with a loud pop, I figured I'd be cutting them out if I ever went with longer coil springs.
TOK is offline
post #39 of 46 Old 10-30-2013, 12:48 PM
duneslider
Glad they worked for you! I know my friend with a winch and stuff on his 2dr has those springs and added a 1/2" spacer to help level it.
07 JKU Wrangler
10 XK Commander Limited
post #40 of 46 Old 10-30-2013, 03:44 PM Thread Starter
SoCal_HEMIHead
The spacers were not too hard to remove. I used a set of large channel locks and was able to pry them out. I will post some pics on the weekend once I have time to take them.
So could I cut the spacers I have to shrink them from 2" to .5-1" ? It seems they are solid and I could just cut them to size without any problems. Feedback?
post #41 of 46 Old 10-30-2013, 03:58 PM
222Doc
222Doc's Avatar
I think it can be done. Not that everyone could though.
222Doc is online now
post #42 of 46 Old 10-30-2013, 05:06 PM
SilverStreaker
So if you're considering cutting down your spacer, would you suggest I just get the 3" springs to start? When you get a chance, can you give me a measurement from the top of the shock mount to the center of the bottom mounting bolt? I'd like to get a better idea of what your setup is now in comparison to mine.
post #43 of 46 Old 10-30-2013, 05:33 PM
SLADE
Do you have the rest of the needed mods/parts to accommodate 3.5" of lift?
2014 Wrangler JKU
2013 Wrangler JK
2001 Dodge Ram 2500
SLADE is offline
post #44 of 46 Old 11-02-2013, 09:51 AM
Ruby_Tuesday
Go out and flex your front axle, that will seat the Bumpstops if they are not already.
Ruby_Tuesday is offline
post #45 of 46 Old 11-03-2013, 11:46 AM Thread Starter
SoCal_HEMIHead
Right now I don't have a need to raise the front any higher. I'm just debating if I should try and sell the two front spacers (if anyone would even buy them) or if I should hang onto them in case I need to add an inch when I install a winch. Alternatively, I could just buy a basic leveling kit if needed at that time.
I measured and I have about 11.5" from the top of the shock mount to the top of the bump stop. About an inch less if you measure from the rim of the shock mount.
It's hard to tell, but I have a couple inches of space now between my front bump stops. No more harsh ride on bumps.
Jeep now sits level and has plenty of space up front.
