TeraFlex 2.5" Budget Boost ? - JeepForum.com
post #1 of 16 Old 01-08-2010, 10:07 PM Thread Starter
jcull35
2010 JK Wrangler
I am looking to put a lil lift on my jk and was look at the TeraFlex 2.5" Budget Boost. I heard that it will affect the ride quality unless a Rear Track Bar Bracket is installed. Has anyone out there put this kit on there jeep and how do you like it.
jcull35 is offline
post #2 of 16 Old 01-08-2010, 10:14 PM
99TJSport
99TJSport's Avatar
I have the 2.5" TF with shock adapters. Very happy with the ride quality. My kit came with a rear track bar bracket in the kit, so I put it in when installing the kit.
Jeff
08 Rubicon Unlimited, 2.5TF Lift, 285/70/17 BFG KM2s, lots of skids, MyGig, and both sets of doors/tops.
Parrothead Jeepers Union #24
99TJSport is offline
post #3 of 16 Old 01-09-2010, 08:14 AM
N2rock
N2rock's Avatar
My wife has it on her JK.
You were mis-informed. The purpose of the trackbar bracket is to re-center the axle. It will not affect ride quality. Without it, your axle will be shifted- the rear axle shifts slightly toward the passenger side, the front axle shifts slightly toward the drivers side. In the case of the TF BB, with stock tires the shift is so minor you don't even see it. If you put on larger/wider tires, then the shift is easily seen because you'll notice the tires sticking out further on the side that the axles shift to. But this shift does not cause any difference in handling or ride quality. With a 2.5" lift, the shift is more cosmetic and does not actually affect anything.
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #4 of 16 Old 01-09-2010, 12:02 PM
Knottymaid
I have a TF BB with shocks and it created issues with my steering geometry. I know lots of folks have good luck with the BBs, I did not. TF is and was aware if the issue, they were happy to sell me a set of $375 lower control arms to fix the problem. We now have many more lifts to choose from and given our present choices I would not go with the TF BB......
Knottymaid is offline
post #5 of 16 Old 01-09-2010, 04:46 PM Thread Starter
jcull35
2010 JK Wrangler
so what would be the best budget boost out there?
jcull35 is offline
post #6 of 16 Old 01-09-2010, 05:05 PM Thread Starter
jcull35
2010 JK Wrangler
I got one more question will the track bar bracket fix the problem?
jcull35 is offline
post #7 of 16 Old 01-09-2010, 05:14 PM
DANJEEPO8
don't have one yet, but because i've been wanting one, i've been reading as many threads about it as possible and it seems like the Rough Country is the best. i think they are the only one with metal spacers, everyone else's is some sort of plastic...(i think)
http://www.roughcountry.com/jeep_jk_2.html
DANJEEP08
DANJEEPO8 is offline
post #8 of 16 Old 01-09-2010, 08:49 PM
river2c
2014 JK Wrangler
Teraflex makes the most complete BB. It comes with a rear track bar relocation bracket, longer rear sway bar links, and brake line extensions. You can order the kit with new shocks or keep your current shocks and use extensions. Most people have been very happy with this starter lift.
2014 JKU Copperhead
river2c is offline
post #9 of 16 Old 01-09-2010, 09:49 PM
Mr. Corrosion
If you move past the spacers and go with the 2.5 coil lift I think you'll be pleased. I know I love mine and have nothing but good things to say about Teraflex products.
2007 Rubicon 2-door, Red Rock
6-speed, Dual tops
2.5" Teraflex Coil Lift, Shrockworks Mid-Width, Warn M8000
Mr. Corrosion is offline
post #10 of 16 Old 01-09-2010, 10:51 PM
rgt75
2014 JK Wrangler
I have the Teraflex BB on my JK and have had no issues with it. I have a TJ as well that my wife drives in the winter and had problems with the Rubicon Express kit I put on it. The bushings went bad after a month and Rubicon Express was less than helpful dealing with it. In fact they basically ignored me. I'd give the Teraflex a shot
rgt75 is offline
post #11 of 16 Old 01-09-2010, 11:08 PM
OregonVette
Hmmm... Well, after speaking with the Jeep Elders, vendors, suppliers, retailers and local shops, I went with the TF 2.5 BB. If you can say one bb puck lift is better than the other than my hats off to you. If someone says RE is better or RC is better or TF is better it is prolly because they have that particular lift already installed on their jeep.
But, why did I choose TF 2.5? Well, because it was the most complete kit and was on a kicka$$ sale for $249
it has the relocation bracket (which is fancy name for small piece of steel with two holes drilled in it) and all the other doo-dads already complete with the kit. That's it / that's all.
Originally Posted by smcutter View Post
It's hard to give you good advice at this point. It's almost like you're saying, "I want to have sex, but don't want to get her pregnant. I can't afford condoms, so for now I just want to use Saran Wrap. What brand would you recommend?"
OregonVette is offline
post #12 of 16 Old 02-28-2011, 10:58 AM
Drayzen
What are everyone's opinions about purchasing the Teraflex shocks with their budget boost? Is it worth the extra money? Is there noticeable difference with everyday driving? Or do the shocks make the most difference off road?
"National Bubble Wrap day just three days before Groundhog Day? WTF, looks like I'm working with a hangover twice this week."
Drayzen is offline
post #13 of 16 Old 02-28-2011, 11:52 AM
GEM1N1
Can't speak for TF but I finally (after months of reading reviews) went with Old Man Emu for my 2.5" BB. I can honestly say that I am EXTREMELY happy with the ride. It is truly better than stock. I think they may be a little more than the TF but I will absolutely be buying them again when they wear out.
2008 2dr Black Rubicon Automatic.
2.5" Rough Country BB
295/70/17 Nitto Trail Grapplers
GEM1N1 is offline
post #14 of 16 Old 01-16-2014, 01:03 PM
Glenntpr1
Here's my review:
2013 JK Unlimited Sahara with TF 2.5 BB lift with Bilsteins 5100s shocks (Note, kept the OEM Sahara Wheels and installed 295/70/18s Nitto Trail Grapplers). P
Completely happy after seeing the appearance improvement after the install. Drove it to the shop for an alignment and the folks at the shop did not want to do the alignment. They finally aligned the jeep and drove off..... The initial reaction from stock to the lift was a mixed feeling. As soon as I drove pass the 50 miles range, the jeep began to slightly swerve to the sides while I compensated the movements with the streering wheel... My wife even asked me to take her back home as she did not feel confortable or safe....
Drove like this for two weeks and finally took it into the city (20 mile drive on the highway). Again, very unconrfable to drive while compensating the movements to stay straight.
Correcting the Problem: Maybe other folks may know this but I did not. Some people appear to have great success with thw kit but I was just simply not very confortable with the swerving and compensation issues..... So drove up to a 4X4 shop and asked them for their opinion. They advised me to install a Pro Comp Adjustable Front Track Bar (07-14 Wrangler JK 4 Door) which they happened to have one on stock for $139.00 dollars. I just told them to go ahead and do the install....... Took it back to the shop and got it realigned for free!!!
Now this thing really drives very well. Some of the other kits come with a track bar. It really helps to be able to adjust the steering and make it more tight. Drives extremely nice and I am very happy with the results. Not sure if putting dual shocks stabilizers on the front will even make it a better ride....
At the end, I do enjoy the jeep with the lift and the trail grapplers.... For now the TF BB meets my needs. I go on trails once in a while but do drive the jeep every day as my commute vehicle...
Thanks,
Glenn
Glenntpr1 is offline
post #15 of 16 Old 01-16-2014, 01:24 PM
bogleparsons
I have the TF 2.5" BB with shocks and couldn't be happier, rides great on 35" tires and looks good.
not one single thing needed that the kit didn't provide.
*edit* did have to buy exhaust spacers, $29.99
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
Alignment issues after Teraflex 2.5'' budget boost installation kam979 JK Wrangler Technical Forum 5 11-12-2008 04:30 PM
Anyone running a Teraflex 1.5" Budget Boost? gtospeeding TJ Wrangler Technical Forum 5 07-17-2008 02:14 PM
TeraFlex 2.5" Budget Boost Kit jlued JK Wrangler Technical Forum 2 08-24-2007 01:20 PM
Teraflex 2.5" Budget Boost rubi2003 JK Wrangler Technical Forum 4 01-16-2007 02:03 PM
Teraflex Budget Boost MrMischief TJ Wrangler Technical Forum 3 04-27-2004 12:21 PM
