A Tale of Two Tops - JeepForum.com
post #1 of 4 Old 12-09-2013, 04:55 PM Thread Starter
MYounts
2014 JK Wrangler
A Tale of Two Tops
My boss (he's a Jeep dealer) gave me two Wrangler soft tops along with all the hardware. One is the stock top and the other is one is a kind of a fast back type (it angles down from the roll bar to the tale gate). I didn't get a chance to see the brand name on it. I'll probably only have it on about two months a year. I'm leaning toward keeping the standard top and selling the other one. But I'm wondering if the fast back one would be easier to put up and take down.
The other question is what's involved with installing a soft top on a Jeep that has never had one. Do you have to drill holes to install the brackets, etc? Or does it bolt right on? If there's drilling I'm probably going to have the dealer do it.
MYounts is offline
post #2 of 4 Old 12-09-2013, 05:51 PM
gwar11d2
2009 JK Wrangler
Lots of videos on youtube. Google/Youtube '2011 jeep wrangler soft top installation'. No drilling required but there are some tricky steps the first time you do it. The 'fastback' top if it is a mopar one will use the factory surrounds (black plastic things) and would probably be easier to take on and off assuming you want to leave the whole rear open to the elements.
Also, in Michigan, you probably don't want to do it in the middle of winter unless you have a heated garage. Soft top material can be difficult to put on or almost impossible when it is cold.
09 JK Jeep Green Sahara Unlimited / Teraflex 2.5" Spring-Shocks / 35's x 16" Level 8 Trackers/ Aussie Locker Front / 5:13's
My Build Thread:
gwar11d2 is offline
post #3 of 4 Old 12-09-2013, 07:24 PM
spinlock
There is no drilling involved. As long as you have all the parts just watch the videos as suggested.
Are the tops the same year as your Jeep? Run a quick search but I believe all years are compatible IF you have all of the soft top hardware. Someone correct if I am wrong.
spinlock is offline
post #4 of 4 Old 12-10-2013, 02:55 AM
SWilliams
I have the Bestop fast top and its a breeze to take off and put on.
SWilliams is offline
