Tailgate weight capacity 200 lbs.?? - JeepForum.com
post #1 of 14 Old 09-15-2010, 11:11 PM Thread Starter
STxWrangler
2010 JK Wrangler
I know that this topic has been hashed around a lot, but I heard something this morning that made me want to ask if others have heard this also.....
I was talking with the 4 wheel specialist that is re-gearing and lifting my Jeep '10 Rubicon and asked about my options for hanging a heavy spare tire, (35 inch Toyo Open Country MT), on the tailgate of my Jeep.
He said that the Jeep tailgate is designed to carry up to 200 lbs. of weight and that I will be fine with the 35 inch spare tire as long as it is well secured and mounted tightly.
I have tried to find information about the weight capacity of the tailgate but have not been able to find any published specs.
I believe what he is saying but I wonder where he got the 200 lb. capacity number for the tailgate.
STxWrangler is offline
post #2 of 14 Old 09-15-2010, 11:14 PM
ncb
No way. The welds will never last on the tailgate.
ncb is offline
post #3 of 14 Old 09-15-2010, 11:17 PM
McKBrew
JK Wrangler
On the same note your tire/rim combo most likely weighs less than 200# (as a guess, probably around 100#) With some extended tire stops from Daystar, you will be fine for the near term.
McKBrew is offline
post #4 of 14 Old 09-16-2010, 12:09 AM
Warlord2
I have had that same tire mounted on my stock bracket for 3+ years with no problem. One thing you need are either extended tire stops or make sure you have a wedge of some sort between the tire and bumper to prevent movement that way. I have 3.75" BS on my rim and the tire is snug up against the bumper. Even jumping the jeep on dunes and going down some nasty whoopties that have smashed my bumperstops I havent seen any bends so far.
NO idea how that mechanic got 200lbs....from chrysler I have read they are only rated for like 50lbs....
07 JK 2D X model with 6 speeds. Full Traction 3" ultimate lift kit. 315x75x16 Toyo Open Country M/T on Rock crawler procomp rim. Ruby dana44's front sleeved inside/outside C truss and rear with 5.13's gears. Homemade rock guards, rear bumper w/tire carrier, oilpan/tranny skid, evap canister skid, light bar, switch pod. Riddler diff covers, Cobra 75 w/wilson antenna, Polk speakers, 10" sub, 2x Amps, Lightforce 240 drive light, backup lights, rock lights.
Warlord2 is offline
post #5 of 14 Old 09-16-2010, 06:33 AM
CGT2358
NO idea how that mechanic got 200lbs....from chrysler I have read they are only rated for like 50lbs[/SIZE]....
I read that in the users manual yesterday...
2008 Sahara Black 6 Speed
Old Man Emu Lift | Pro Comp 7005 17x9 | Goodyear Wrangler MT/R 285/70R17 | PSC Brawler Lite Front Bumper | Smittybilt XRC 8 | JKS Front/Rear Track Bar | JKS Quick Disco Front Sway Bars | KC HiLite
CGT2358 is offline
post #6 of 14 Old 09-16-2010, 08:23 AM
aristobrat
2010 JK Wrangler
If it helps any, here's the exact quote from page 443 of the owners manual (2010-Wrangler-OM-3rd.pdf):
NOTE: If you have added aftermarket accessories to the spare tire mounted carrier, it cannot exceed a gross weight of 50 lbs (23 kg) including the weight of the spare tire.
aristobrat is offline
post #7 of 14 Old 09-16-2010, 09:57 AM
DeepSky
You may want to educate that mechanic, otherwise there's going to be some PO'ed customers coming back to him wondering why their tailgates are popping welds.
IMO you can run a 35" on the tailgate for a while as long as you prevent it from jossling around with the Daystar tire stops and resting it on the bumper, but that's with a "normal" 35. I personally wouldn't put a Toyo MT on the tailgate for any extended period of time, that is a heavy *** tire.
2003 Patriot Blue Wrangler SE - RCX 2.5" Kit on 31x10.5 Firestone M/Ts and stock the rest of the way.
2007 Flame Red Wrangler Unlimited X - Skyjacker 4" Kit on 35x12.5 Cooper Discovery STT(
DeepSky is offline
post #8 of 14 Old 09-16-2010, 10:09 AM
ncb
The tailgate is rated for more than 50 pounds because the Rubicon wheel/tire weighs 74 pounds.
ncb is offline
post #9 of 14 Old 09-16-2010, 12:51 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Yup...Chrysler rates the tailgate tire carrier at 50 lbs and then hangs the 74 on them...go figure, but that is the fact. I think the mechanic got the 200 lb from the recommended dead hitch weight limit on the trailer hitch rating...not the tire carrier.
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #10 of 14 Old 09-16-2010, 01:33 PM
DeepSky
That's interesting...
Well just so the OP knows, one Toyo open county MT weighs 83lbs by itself.
DeepSky is offline
post #11 of 14 Old 09-16-2010, 02:39 PM
Blu-Jacket
2009 JK Wrangler
That is heavy! My BFG KM2 35 MT+AEV Pintler was only 95lbs combined. I would think short term you're ok, but for the long haul you might want to start saving for a carrier.
Blu-Jacket is offline
post #12 of 14 Old 02-18-2015, 08:37 AM
Arjis
I've had a 35" BFG Mudder on my 2012 Unlimited since I bought it and added a RR Hi Lift mount with absolutely no issues.
Arjis is offline
post #13 of 14 Old 02-18-2015, 09:28 AM
1222
RIP John
1222's Avatar
The trick is to get the spare mounted tight utilizing tailgate snubbers, bought or fabed. If the tire is not tight then it will lead to failure down the road.
(2011-2016)
1222 is offline
post #14 of 14 Old 02-19-2015, 03:53 PM
AJKJK
This.....
AJKJK is offline
JK Wrangler , spare tire mount , tailgate , weight capacity , weight limit , wrangler
Stock tire weight/size capacity? Fomocofan302 TJ Wrangler Technical Forum 7 03-30-2010 09:22 AM
Help- towing weight capacity question roro990323 TJ Wrangler Technical Forum 10 02-06-2008 08:09 PM
How much weight on TJ tailgate? fowlball TJ Wrangler Technical Forum 4 02-01-2008 10:20 AM
Hard top roof rack/weight capacity? Gunnison TJ Wrangler Technical Forum 15 07-06-2007 02:26 AM
Rear Tailgate Maximum Weight DouginTN TJ Wrangler Technical Forum 2 02-15-2004 08:40 AM
