Tailgate issue - JeepForum.com
post #1 of 7 Old 04-02-2015, 12:10 PM Thread Starter
psheffern
Tailgate issue
So my tailgate is really starting to rattle. I have 35" tires and the spare is mounted right to the gate.....i know i need to do something soon, that rattle is driving me crazy...but i have no money, so....are those reinforcing kits any good, or should i just start saving for a bumper and carrier?......or can a carrier be rigged to a stock bumper somehow.....please
psheffern is offline
post #2 of 7 Old 04-02-2015, 12:43 PM
1222
RIP John
1222's Avatar
Have you tried trouble shooting the problem? For instance, if you grab the spare and pull up and down and in/out can you get the tailgate to move? It may just be as simple as adjusting the striker plate. Perhaps not but that’s where I would start.
EDIT: Also, is your tire snubbed up tight against the tailgate? If not then depending how long this has been going on you may have more serious problems.
(2011-2016)
1222 is offline
post #3 of 7 Old 04-02-2015, 01:19 PM Thread Starter
psheffern
with the gate shut...and me pulling /puching on the tire...it rattles the metal of the gate where it is attached....so not the hinge area...that make sense?....so you think it could just be tightend....guess i could try that...didnt even think of that
post #4 of 7 Old 04-02-2015, 01:22 PM Thread Starter
psheffern
EDIT: Also, is your tire snubbed up tight against the tailgate? If not then depending how long this has been going on you may have more serious problems.[/QUOTE]
sorry over looked this part.....the tire is not very snug, i have bump stops that are about 5-6" long....but i dont have a choice on that because the tire would rub on the bottom if i got any closer
i have owned it for two years now and this is the first for the rattle, but i dont know how long this has been fitted this way...i can try the removal and tighten like you said first and go from there....
post #5 of 7 Old 04-02-2015, 01:29 PM
duneslider
When I had a rattle it was the latch. I adjusted the catch and the wedge shaped deal and the rattle went away.
07 JKU Wrangler
10 XK Commander Limited
duneslider is offline
post #6 of 7 Old 04-02-2015, 02:02 PM
SlyDawg64
SlyDawg64's Avatar
2014 JK Wrangler
A friend had the rattle and it turned out to be the hinge bolts. one was almost completely out.
New:
2014 JKU Rubicon, Copperhead Pearl, 3" TerraFlex lift, Toyo MT 35x12.5x18 tires, Warn Powerplant,
Old:
2010 JK Rubicon, 2 dr., 3" Terraflex lift and adjustable rear track bar, Toyo 35x12.5 tires, custom bumpers, Warn Powerplant, KC lights, B&M trans cooler, etc.
SlyDawg64 is offline
post #7 of 7 Old 04-02-2015, 02:42 PM Thread Starter
psheffern
ok i guess i have a project this weekend.....if the wife lets me with Easter and all....thanks guys
