Synergy Suspension Ball Joint Set Experience? - Page 3 - JeepForum.com
post #31 of 43 Old 07-13-2013, 05:05 PM
SubAtomicGenius
2011 JK Wrangler
Again, sorry to hear that you had a bad experience. However, I'm a firm believer in the one-in-ten rule: for every one person who encounters a problem with a product, chances are there are 10 (or more) people who are satisfied.
I personally installed my Synergy ball joints, greased them initially, greased after a break-in of about 1000 kms (regear break-in period), and now regularly with oil changes. I've beaten my rig offroad, she is my DD, and I've had her up in the lift and she's given me no indication of worn ball joints whatsoever.
I'll be sure to keep you posted if I encounter any problems.
I'd highly encourage all end-users of Synergy Ball joints to chime in - whether positive or negative to get a real feel about how this product is. If they are problematic - I'm sure that everyone would like to know. I've scanned the threads about the comparisons between the Synergy ball joints and the stock ones - between that and the price - that is what sold me in the past. So far so good.
SubAtomicGenius is offline
post #32 of 43 Old 07-13-2013, 07:04 PM
kody4
I'm not saying synergy is junk either because I have a lot of synergy parts and they have held up very well but the ball joints to me where pretty disappointing. I did email them to see what there input is and if they will warranty them. Still waiting to hear back. I could have just got a bad batch
kody4 is offline
post #33 of 43 Old 07-13-2013, 07:16 PM
brianjw
Installed mine last November and I've put around 10k miles on them with 35s. No signs up anything loose up front (all synergy components).
Lots of hard offroad, hundreds of miles off nasty washboard, sand, snow, mud, water etc.
I greased mine on installed, frequently initially and now at least every 3k miles when I change the oil. More often if I've been in lots of water/mud or ******d the underside with a pressure washer.
brianjw is offline
post #34 of 43 Old 07-13-2013, 11:02 PM
1222
RIP John
1222's Avatar
Originally Posted by kody4 View Post
my synergy ball joints failed after three months and only about 3k miles. the lowers are looser now then the oem ones ever got. my jeep is only on 35 inch tires and I grease everything on a regular basis. to be honest im pretty disappointed with them. IMO
Are you sure that they failed? You started a thread “Synergy ball joints” were I posted (post #6) to explain what you are most likely experiencing with the used Synergy’s in hand.
1222 is offline
post #35 of 43 Old 04-02-2016, 08:53 AM
lumpster
lumpster's Avatar
we just had synergy ball joints installed earlier this week. they seem very stiff, jeep lost a significant amount of return to center on the highway, and jacking up the front end off the ground, the steering wheel is still really tight to turn.
I'm not happy with them, I wish I would have looked into the teraflex ball joints.
lumpster is offline
post #36 of 43 Old 04-02-2016, 09:04 AM
JIMBOX
That's too bad-sorry-
Were they greased on installation--
No grease/no move-
Mine have been flawless for almost 5 years-
Bummer, but they've gotta be greased every 3k miles--BY HAND--not pressure lube-
Good luck
JIMBO
Yellow Jeep No. 683
--YA GOTTA HAVE CLASS--
JIMBOX is offline
post #37 of 43 Old 04-03-2016, 01:58 PM
duneslider
Jimbo, what you mean by "not by pressure lube"? Every grease gun whether hand pumped or air pumped is exerting significant pressure to push grease through a zerk and into where it needs to be?
07 JKU Wrangler
10 XK Commander Limited
duneslider is offline
post #38 of 43 Old 04-03-2016, 02:26 PM
JIMBOX
That's right, but with the hand gun you regulate the EXACT amount you'll verify by sight !
Too many of our jeepers goto "JiffyLubes" to have their oil changed and then could/use the commercial grease app. guns and almost every time the BJ seal is broken--
If you doit by hand you can apply the grease "GENTLY" and watch for the seal expansion-
I think you know this-
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #39 of 43 Old 04-04-2016, 10:57 AM
propped1
I have a set of Synergy upper and lowers that have been good for almost 4 years. Greased regularly. Never seen this thread and a lot this is from years ago, but those saying that the return to center or steering is stiffer is probably looking at improper installation. This shouldn't be a factor at all.
The Teraflex ones (unless they redesigned) lowers get in the way of larger hub U joints if you upgraded or intend to. Other than that, heard nothing but good things. The Dynatracs are rebuildable, but you can get 2 sets of synergys for the price. How often you gonna rebuild them? I evaluated all of these 4 years ago when I bought mine.
I also heard that balls are a pain in the you know what, so I had a shop professionally install instead of doing it in my driveway... make a difference? Maybe a little...
._______
/_l__[___],
l--|--|--L
-OlllllllO]
(o)_) (o)_)o-)_)
propped1 is offline
post #40 of 43 Old 04-04-2016, 01:20 PM
mrwhipple
They should break in a bit.
silver jkur
mrwhipple is offline
post #41 of 43 Old 04-04-2016, 03:27 PM
JIMBOX
Well, I don't think so--
They're a free rotating joint, just like a hip joint and MUST have lubrication--
I think the installation and final FIT is what's important--mine were free, no resistance immediately after install and with constant lube--PRIMO !
JIMBO
Yellow Jeep No. 683
JIMBOX is offline
post #42 of 43 Old 04-04-2016, 06:04 PM
mrwhipple
Over the stock ones they are a bit tighter feeling. tighter. Mine loosened up a bit after a week or so but they are a little stiffer than stock.
But then again my stock ones weren't new either when I had them replaced.
silver jkur
post #43 of 43 Old 04-05-2016, 10:18 AM Thread Starter
vgullotta
If they are stiff, something is not right. Grease them again, and if that doesn't fix it, I would take it somewhere and have someone take a look. With the front end off the ground, if it is tight to turn the wheel, there is a problem and the vehicle may not be safe.
vgullotta is offline
Synergy ball joints? btn TJ Wrangler Technical Forum 7 05-26-2014 12:41 AM
Synergy Suspension Ball Joints and 37s??? hulud44 TJ Wrangler Technical Forum 17 02-02-2012 11:02 AM
Synergy Suspension HD Ball Joint sets Baseplate TJ Wrangler Technical Forum 1 12-07-2011 06:45 AM
Synergy Suspension Brake Line Extension Brackets Jeffro3000 JK Wrangler Technical Forum 6 07-06-2011 04:14 PM
Suspension and Ball Joint Lube Question TJShadow TJ Wrangler Technical Forum 6 10-15-2008 10:15 AM
