Why would you want to buy a control arm thats been broken, even if they fixed it?
(I know that's just WRONG)... 😁
Ditto on adj. - jus be careful, some don't go as short as OEM if your trying to stay in that geometry.
If you're going to replace the OEM control arms, then you should go ahead with adjustable instead of fixed. But, are you sure that you need to replace them? Is your alignment off, or are you upgrading to something stronger? I installed a 2.5" lift and my alignment is fine. No reason to spend the money if you don't have to.
Your caster is off at 2.5". Will it work, sure in most cases. Jeep fronts can have a few things out before the main issue appears , DW. Toss in a unbalanced tire and a bit of caster lose maybe a loose part and there you go.
Another thing depending on your mechanical ability. No need to pay people to set caster. just a angle finder, mag base will do well. Same for toe, a tape measure will do... i just saved you 100$ simple stuff really. Now you cane get better arms, maybe with JJs. of the few things simple on a Jk its still the front end. even easier than a TJ to set. No inverted Y. just a straight tie rod. like a farm tractor.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
