Synergy coil spacers - JeepForum.com
post #1 of 7 Old 07-14-2013, 05:58 PM Thread Starter
DuckRunner09
1989 XJ Cherokee
I'm ordering a set of synergy coil spacers this week from krawl off road. Anyone running these? I'm debating whether to get 1 3/4 for both front and rear or should I go with the 3/4 in the rear and the 1 3/4 in the front? Not sure how that would look but it seems like most lifts are slightly taller in the front. I do plan on adding a winch eventually and heavier bumper at some point if that helps.
I don't get lost, just temporarily misplaced
'12 JK-built and wrecked
'89 XJ-work in progress
DuckRunner09 is offline
post #2 of 7 Old 07-15-2013, 06:49 AM
Remmy18
I don't have the Synergy but have the TF leveling kit (2" front 1" rear) and love the stance. Took the rake out. I'd definitely go an inch bigger in the front if you're going to add weight up there. Hope that helps somewhat.
Tried to post a pic but got denied by file size...
Remmy18 is offline
post #3 of 7 Old 07-15-2013, 06:51 AM
Remmy18
Tried it again.
Remmy18 is offline
post #4 of 7 Old 07-15-2013, 06:57 AM Thread Starter
DuckRunner09
1989 XJ Cherokee
Awesome thanks!
post #5 of 7 Old 07-15-2013, 07:01 AM
Remmy18
No prob man. Just be prepared that if you're going with a heavy winch and bumper combo eventually, the stock springs will sag with the added weight and put you close to stock height even with the spacers. That's why I am not going with a heavy aftermarket bumper and a winch with synthetic line for reduced weight. Just a heads up and good luck.
Remmy18 is offline
post #6 of 7 Old 07-15-2013, 09:21 AM Thread Starter
DuckRunner09
1989 XJ Cherokee
Well I'm looking at smaller winches, figure I'd rather have a 6k rated winch with synthetic line and a snatch block than a heavy 9k winch. I won't be running a heavy bumper quite so soon though. Figure maybe next summer I'll hit the drawing boards and fab up my own then. Maybe by then I'll have money for a real lift anyways.
post #7 of 7 Old 02-06-2015, 06:47 AM
mmarriott
2015 JK Wrangler
mmarriott
Do I need to do any other mods If I add the 1 3/4 spacers? any other parts or can I use stock shocks and such.
mmarriott is offline
