Synergy ball joints - JeepForum.com
post #1 of 6 Old 07-13-2013, 03:29 PM Thread Starter
kody4
Synergy ball joints
Ok guys I am replacing all my steering with the poly tie rod flip draglink and reid knuckles. When I pulled my factory knuckles off last night I noticed how sloppy my new synergy ball joints felt with about 3k miles on them. They where really loose. Any suggestions thanks
kody4 is offline
post #2 of 6 Old 07-13-2013, 04:52 PM
SubAtomicGenius
2011 JK Wrangler
Sloppy as in easily moved or sloppy as in the ball joint feels wore? These are greased ball joints as well, did you grease during install? I have heard of people having shops install aftermarket ball joints and the shop doesn't grease them because they are used to permanently sealed ball joints rather than the grease-able kind. In this case (like most any other): no grease = trouble.
SubAtomicGenius is offline
post #3 of 6 Old 07-13-2013, 06:58 PM Thread Starter
kody4
Ya I grease everything on a regular basis but the lowers are very easy to wiggle if that makes sense they started out firm and the uppers, the shaft slides up and down about a half inch inside themselves now
kody4 is offline
post #4 of 6 Old 07-13-2013, 07:17 PM
brianjw
I believe they are supposed to move up and down. Can't remember if the uppers or lowers are supposed to do that but I'm pretty sure one end is.
Out of curiosity, is your front axle gusseted?
brianjw is offline
post #5 of 6 Old 07-13-2013, 07:28 PM Thread Starter
kody4
Ok I have been trying to figure that out and yes my front end has artec industries truss gussets. Chromoly shafts arctec hd trackbar mount raised to the 3inch setting
kody4 is offline
post #6 of 6 Old 07-13-2013, 10:44 PM
1222
RIP John
1222's Avatar
The uppers are supposed to go straight up and down, they are designed that way but no side to side movement should be noticed. The bottoms will rotate in all directions but not up and down. When you first installed them both the uppers and lowers are stiff and a bit hard to move, that’s normal but after use they will become like you described them.
1222 is offline
