Switching to RK 2.5" coils - JeepForum.com
post #1 of 8 Old 12-28-2014, 12:01 AM Thread Starter
Sierra141
2010 JK Wrangler
Do you guys think I will have any problems running Rock Krawler 2.5" triple rate coils. I will be eliminating the front spacers by Teraflex, I currently have the BB kit. The reason i did this is to eliminate the front rake that is driving me crazy. My research shows that on a 4 door it will net 3" of lift with the RK 2.5" coils. I already have rancho 9000's for up to 3.5" of lift. Has anyone done this before and leaving the Teraflex rear pucks on, but switching to springs before. I will not be disconnecting the sway bars until I get longer brake lines and maybe exhaust spacers, mine is a 2014 JKU
Fyi got a killer deal on the RK coils for 118.00 free shipping
Sierra141 is offline
post #2 of 8 Old 12-28-2014, 10:09 AM
HOKIES2010
2011 JK Wrangler
I had the 3.5 coils from RK. I switched to HD 4" OME coils. I really wish I hadn't, my RK coils ride so much better and were more stout. I installed the 2.5 RK kit on my buddy's 2015 JKUR and he loves them.
My Build
Couldn't have done it without
HOKIES2010 is offline
post #3 of 8 Old 12-28-2014, 11:25 AM Thread Starter
Sierra141
2010 JK Wrangler
Thank you for the heads up, i've heard nothing but good things from RK
post #4 of 8 Old 12-28-2014, 01:31 PM
janders82
2010 JK Wrangler
Originally Posted by Sierra141
Do you guys think I will have any problems running Rock Krawler 2.5" triple rate coils. I will be eliminating the front spacers by Teraflex, I currently have the BB kit. The reason i did this is to eliminate the front rake that is driving me crazy. My research shows that on a 4 door it will net 3" of lift with the RK 2.5" coils. I already have rancho 9000's for up to 3.5" of lift. Has anyone done this before and leaving the Teraflex rear pucks on, but switching to springs before. I will not be disconnecting the sway bars until I get longer brake lines and maybe exhaust spacers, mine is a 2014 JKU Fyi got a killer deal on the RK coils for 118.00 free shipping
2010 JKU...i had the TF 2.5" BB with the Rancho 9000s...ended up replacing the BB with the 2.5" RK Triple rates on all 4 corners. I definitely gained at least another 1/2" from the swap. The ride is awesome. no issues what so ever.
install was super easy. took me about 2.5 hours start to finish to swap the pucks/springs out.
my guess is you might have a bit of a "reverse rake" if you only opt to switch out the fronts...
2010 JKU Automatic w/ 5.13 Gears
2.5" TeraFlex w/ Rancho XL9000s
17" XD Addicts
295/70/17 Nitto Trail Grapplers
janders82 is offline
post #5 of 8 Old 12-28-2014, 01:53 PM
DSC330
2014 JK Wrangler
Yeh my only guess would be you would have it in the rear. Just go for front and rear coils. RK is great. I have 3.5 x factor kit on my 2014 jku
DSC330 is offline
post #6 of 8 Old 12-28-2014, 02:01 PM Thread Starter
Sierra141
2010 JK Wrangler
Thanks for all the help guys, that 1/2" is what i'm trying to accomplish. Eventually i will do the rears as well.
Cheers:::
post #7 of 8 Old 01-11-2015, 02:05 PM Thread Starter
Sierra141
2010 JK Wrangler
Install was soo easy,. Thanks for all your help
post #8 of 8 Old 01-11-2015, 02:25 PM Thread Starter
Sierra141
2010 JK Wrangler
Originally Posted by sierra141
just installed the 2.5" triple rate coils by rock krawler pulled the bb spacer out in the front only, and wow they are great it rides so much better, the ride is very car like. Thanks for all your help
