Switch panel above the radio ..... - JeepForum.com
post #1 of 48 Old 08-18-2009, 08:36 PM Thread Starter
Dr.Dirty
Well I needed some more switches .......So 12volt guy to the rescue He has made a upper panel for the JK And i cant wait for it to arrive here are some teaser pics he sent me i will post more pics when i recieve and install it
hope you enjoy these are like porn for me
*UPDATE*
Dr.Dirty is offline
post #2 of 48 Old 08-18-2009, 08:45 PM
ge2
Gold Member
ge2's Avatar
DIG it! Totally DIG it. Nicely done.
ge2 is offline
post #3 of 48 Old 08-18-2009, 08:49 PM Thread Starter
Dr.Dirty
he did an awesome job
Dr.Dirty is offline
post #4 of 48 Old 08-18-2009, 09:12 PM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
woah
I want that!
-Matt
mattman8706 is offline
post #5 of 48 Old 08-18-2009, 09:26 PM
Prot
Prot's Avatar
2014 JK Wrangler
I really like it, but my question is how high does it sit? Does it cause any obstruction to your vision?
2014 JKU Copperhead Pearl
Too many mods to list. Too awesome to sell.
Prot is offline
post #6 of 48 Old 08-18-2009, 09:47 PM
wrestlerobx
I have read a lot of post where putting cell phones in the daystar dash and other small electronic devices will cause interference with the compass or something. So i dont see this doin it but maybe something you could let us know about.
Thanks
JEEP
wrestlerobx is offline
post #7 of 48 Old 08-19-2009, 07:39 AM
N2rock
N2rock's Avatar
That is TOO COOL!
OK- spill the beans. How much?
for details and info on our JK's, check out
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline
post #8 of 48 Old 08-19-2009, 07:42 AM
mattman8706
2009 JK Wrangler
dang it looks even cooler this morning.
That is the sweetest switch panel I have seen.
-Matt
post #9 of 48 Old 08-19-2009, 07:43 AM
N2rock
N2rock's Avatar
what's the big "socket" on the right side? Winch controller plug in?
N2rock is offline
post #10 of 48 Old 08-19-2009, 07:46 AM
mattman8706
2009 JK Wrangler
I thought it was a 12V outlet...
-Matt
post #11 of 48 Old 08-19-2009, 07:54 AM Thread Starter
Dr.Dirty
i love it between this and my sPOD i should have all my switch needs taken care of
Its a extra 12v power outlet
you are correct
That is TOO COOL!
here is a quote from 12voltguy he is awesome to deal with and will go out of his way to get you what you want
"$399 & up
9.5" wide take up to 9 full size switches, could do many more mini type & I can also do carling rockers, I think 8 of those, even the carlings can be used as winch in/out if you want a smooth look of everything the same
comes loaded with output wires, & 1 wire input, with fuse block of some sort
& a maxi fuse for battery side or circuit breaker
those silver bars on bottom are only hole drill jigs, use them to get holes perfect & toss away
I mounted one on the stock plastic & used 1/4" holes so you have plenty of adjustment.
This took alot of work & 6 month wait to get time to do it, but I think in the end it's worth the wait.
this one has a 6 circuit
I might end up mouning a 8 circuit in panel thsat sticks out top or side like my comp panels
must be sure this clears roll cage, or I redesign it
stay tuned, it will be shipped in a few hours
I can also make in BRUSHED or POLISHED too. "
Dr.Dirty is offline
post #12 of 48 Old 08-19-2009, 07:56 AM
N2rock
N2rock's Avatar
Wow- That is not a bad price at all considering all the work that goes into it.
N2rock is offline
post #13 of 48 Old 08-19-2009, 08:18 AM
mattman8706
2009 JK Wrangler
yeah that isn't a bad price at all.
Yours has the perfect amount of switches. Pretty much everything you would need.
I need to get one of these now
-Matt
post #14 of 48 Old 08-19-2009, 12:00 PM Thread Starter
Dr.Dirty
He is an awesome guy to deal with and he will go out of his way to make sure that you get the layout you want
Dr.Dirty is offline
post #15 of 48 Old 08-20-2009, 09:44 PM Thread Starter
Dr.Dirty
Well i got her today and WOW what a gorgeous part....... after the mock up all looked well so i continued and well...... it hits the cage:bawling: no biggie it is being sent back tomm for a a redesigned replacment what kind of service is that :grinpimp::grinpimp: so while i have to wait a bit longer to enjoy it , the wait is well worth it
here are the few pics i took
Dr.Dirty is offline
Radio delete plate / double switch panel install southbound YJ Wrangler Technical Forum 14 10-28-2010 05:57 PM
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
switch panel ARCHERYNGUNS JK Wrangler Technical Forum 30 04-15-2009 02:55 PM
ARB switch panel - NEW! Stu Olson TJ Wrangler Technical Forum 10 02-16-2008 04:04 PM
how does the switch panel come off? wingman TJ Wrangler Technical Forum 3 11-23-2003 03:37 PM
