Quantcast Swaybar disconnect = punctured tire - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Swaybar disconnect = punctured tire
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 10-20-2007, 07:29 PM   #1
N2rock
N2rock's Avatar
Was out running some trails today. Had the swaybar disconnected and strapped up out of the way with wire ties. While making a tight left turn (had the wheel turned all the way to the stops), the right wheel was off camber, maneuvering very slow. The swaybar punctured the sidewall of the tire
We were lucky in that we had been in a lot of mud all day, but the spot where this happened was pretty solid- I was just getting ready to turn into some more water/mud. After we got the wheel changed, we started checking it out closely and determined that with the swaybar disconnected and tucked up as far as possible out of the way, and the wheel off-camber and turned to the stop in the opposite direction, the swaybar is pushed against the tire sidewall. It only occurs when the wheel is off-camber. This was a bit of an expensive lesson to learn being as the tire only has 3000 miles on it.
Oh well- live and learn.
for details and info on our JK's, check out http://n2rock.com
His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list
Hers: '08 X Red Rock, soft top, auto. Bunch of mods
Originally Posted by tlgraham View Post
If you made a snuggy out of a Shamwow, ....would you have to get up off the couch to pee?
Originally Posted by Deepskyy View Post
At this point if Obama tried to move a little to the right, he would trip over Stalin's corpse.
N2rock is offline   Reply With Quote
Old 10-20-2007, 08:34 PM   #2
richnev
that jeep is pretty clean to have been in mud all day =)
but glad it happend on dry ground
05 Jeep Wrangler X .... RIP
07 Jeep Wrangler Unlimited X ...... let the build begin
ARMY TEAM MEMBER #4
Originally Posted by ge2 View Post
I just make a BOOP BEEP sound with my mouth (really loud) as I walk away from the jeep, and point the key at it.
Originally Posted by her94yj View Post
lets put it a way a kids will relate......its like a hooker.......... SURE a 15 dollar handy from a detroit toothless 60 year old can get it done....... but NO where is it as nice as the $5000 an hour goddess from vegas or hollywood
....... dont be that fat guy on the beach in the speedo you dont want to be "that guy"
richnev is offline   Reply With Quote
Old 10-20-2007, 11:52 PM   #3
lrjeep
Sucks to lose a tire like that. On the good side you can finally get some off road tires!
lrjeep is offline   Reply With Quote
Old 10-21-2007, 03:35 AM   #4
JK_Jeep
Originally Posted by N2rock
From what I can see is there was a ghost near by and that may have caused the flat, look at the orb
ooooooooooooooooooooooooooooo boogedy gooogedy
IT'S A JEEP THING!
Originally Posted by sierraexplorer
Thanks, if it is that good than I'm sure that they can't sell it in California. Everything else is illegal in this state except the illegalsl
JK_Jeep is offline   Reply With Quote
Old 10-21-2007, 05:14 AM   #5
roc4117
Go Broncos!!!
roc4117's Avatar
Did you have the electronic front sway-bar disconnect that you can order from the factory or was it a manual after-market one that you installed? Just curious, I ordered the factory one and just wondering if it's something I need to watch out for. Thanks.
Rock
Freedom has a taste that the protected shall never know
Colorado Jeep Club Member #115
roc4117 is offline   Reply With Quote
Old 10-21-2007, 07:12 AM   #6
N2rock
N2rock's Avatar
Neither- The old fashioned method- unscrewed the bolts, swung the swaybar up out of the way and wire tied them up. Hopefully you won't have that problem with the factory disconnect, but I would definitely check to make sure. Get the right front up higher than the left and turn all the way left, then check to see the clearance. And apparently this happens on both sides because when I went to hook the swaybar back up in the afternoon, you could clearly see that the left had rubbed too.
When we studied it, on level ground there was no rub. But any off-camber caused it to rub. Looks to me like I need to get some new rims with less off-set to set the tire out just a bit further.
Old 10-21-2007, 07:17 AM   #7
N2rock
N2rock's Avatar
This happened within the first 30 minutes- we had hit only a few tiny patches of mud by this point. If you look at my 2nd picture- that "white" looking area above my hood, that's all water & mud. I was trying to make that turn to go in between those trees when it popped- BANG! SSSSSSSSSSSSSSSSSSSS Wasn't the sound I wanted to hear
Old 10-21-2007, 09:06 AM   #8
N2rock
N2rock's Avatar
Spare tire- what should I do
Had a little mishap wheeling yesterday- http://www.jeepforum.com/forum/f96/swaybar-disconnect-punctured-tire-476021/
So now I have no spare tire. Obviously I need to rectify that. Looking online I see the Goodyear Wrangler (which is what is on the Jeep) is $163 (although the only one I find online is the "silent armor", and I'm betting that is not the same as the stock ones).
But... I my ultimate plan is (once I wear out these stock tires) is to switch to a better off-road tire, like maybe a BFG MT.
I only have 3000 miles on the stockers though.
So my dilemma- do I go ahead and replace the spare with a Wrangler for $163 (so I still have a matching spare), or go ahead and replace the spare with a BFG. The real dilemma is that hopefully I will never need to use the spare. In which case the $163 would be wasted money. The BFG is a bit more money, but... If I do actually ever need to use the spare, it will be a mis-match.
Opinions?
Old 10-21-2007, 09:17 AM   #9
ge2
Gold Member
ge2's Avatar
Man-- I'm so sorry to read that other thread. That sucks. Glad you made it out ok.
My input..... you'd better just go with a spare that matches for now. Hopefully you never have to use it, and maybe you can sell it as new later, but I'd go for the goodyear, myself.
ge2 is offline   Reply With Quote
Old 10-21-2007, 09:23 AM   #10
N2rock
N2rock's Avatar
hmmmm... another option- I just check local craigslist, and there is someone listing 2 wheels (same rim and tire as my stock), $200 for the pair. I'm starting to think that since it is going to cost me around $200 for new (with mounting and balance), I might just buy that pair of tires, and then I have an extra "spare" in the garage.
Old 10-21-2007, 09:24 AM   #11
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
If all 4 on your vehicle match, then get the bfg spare that you want. Depending on how long it takes to wear out your tires that spare may be dry rotted by the time you go to use it, but if not then you have 1 less tire to buy. If anything buy a jeep spare tire cover for it so no one can see that it is mismatched.
Or just sell all the good tires off your rig and get the bfg's you want, i can guarantee once you get over the initial cost you will not regret it .
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Wilmington weekly 4x4 meet
Jakemd98 is offline   Reply With Quote
Old 10-21-2007, 09:27 AM   #12
Jakemd98
Jakemd98's Avatar
Man that does suck, but that's also why you have a spare. That's just how it goes when you go off-roading, and you just have to accept the fact that something may break when out playing. But when something does break it means that it is time to up-grade .
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Old 10-21-2007, 09:37 AM   #13
igofshn
Locked @ both ends
igofshn's Avatar
Your threads were merged. You don't need 2 threads on the same subject.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Old 10-21-2007, 09:45 AM   #14
N2rock
N2rock's Avatar
OK... But I really don't think it was the same subject
1st was what happened, and serves more as a warning to others
2nd was asking for opinions on what I should do about replacing my spare. And really, that is more what I want opinions on at this point. Unfortunately you merged it with the swaybar thread, so now I'll get less (if any) opinions on replacing the spare
Old 10-21-2007, 09:48 AM   #15
N2rock
N2rock's Avatar
Not really worried about the mismatch as far as looks. I'm more concerned with the mismatch if I ever have to use the spare. Would there be any issue with having one BFG on?
Glock Forum
