Sway extensions? - JeepForum.com
post #1 of 7 Old 08-20-2013, 02:43 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Sway extensions?
I have been looking at several 2-2.5 inch suspension lift. Some include sway extensions, some not. What are you guys feelings on the need for these. Also same question on brake line brackets.
FIRECAPT is offline
post #2 of 7 Old 08-20-2013, 05:30 PM
Lynhalla
Lynhalla's Avatar
What kind of wheeling you going to be doing? Extended sway bar links and brake line brackets allow you to have more articulation when going over obstacles and keep your tires on ground, therefore more traction. If it's mostly for looks and bigger tires and not trail riding, not a necessity.
___________________
2008 JK Unlimited X
RIPP stage 2 supercharger, R/K xfactor 5.5" long arm coilover susp., 40"x13.5" G/Y kevlars, 17x9.5 Raceline beadlocks, EVO gussets and sleeves, Yukon chromoly shafts, Artec trusses, T/W drive shafts, Eaton lockers, G2 5:13 gears, ORFAB front bumper with smittybuilt 12000 winch, Body Armor rear bumper, ORFAB roll cage, Mastercraft Baja seats, SPOD
Lynhalla is offline
post #3 of 7 Old 08-20-2013, 06:41 PM Thread Starter
FIRECAPT
2010 JK Wrangler
Some trail riding with some flexing, so I kind of feel a need for it.
FIRECAPT is offline
post #4 of 7 Old 08-20-2013, 07:53 PM
TheBoss
Longer sway bar links are to keep the anti swaybar in the level or neutral position for on road driving. If you have a non rubicon and do any type of off road low speed driving get adjustable disconnects for the front. Disconnecting will keep the wheels in contact with the terrain instead of lifting due to the axle being restrained by the sway bar.
Brake line extensions are a must if you lift and articulate the Jeep other wise you will risk ripping the brake line on the trail ,not good.
TheBoss is offline
post #5 of 7 Old 08-20-2013, 10:56 PM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by TheBoss View Post
Longer sway bar links are to keep the anti swaybar in the level or neutral position for on road driving. .
and thats the only reason!
Good advice in the rest of this answer as well.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is offline
post #6 of 7 Old 08-20-2013, 11:03 PM
brianjw
Actually that's not the only reason. If the end links are too short for the suspension travel, the sway bar can become bound up under full droop and the end link and end of the sway bar can get in line with each other and break the end link.
I believe there have even been recent threads with this very problem.
brianjw is offline
post #7 of 7 Old 08-20-2013, 11:11 PM
jwmbishop
jwmbishop's Avatar
2011 JK Wrangler
Originally Posted by brianjw View Post
Actually that's not the only reason. If the end links are too short for the suspension travel, the sway bar can become bound up under full droop and the end link and end of the sway bar can get in line with each other and break the end link. BECAUSE THE NUETRAL POSITION IS NOT LEVEL TO THE GROUND SO THE TRAVEL IS STARTING TOO CLOSE TO THE EXTREME OF THE ARC...
I guess I stand corrected...
