sway bar question - JeepForum.com
post #1 of 3 Old 09-06-2012, 07:17 AM Thread Starter
jzman10
2009 JK Wrangler
sway bar question
looking at my jeep one if the front sway bar is not there..how much will that mess up the handling of the jeep..can i go get just one sway bar or do i need to get a new set??thanks
jzman10 is offline
post #2 of 3 Old 09-06-2012, 08:12 AM
GPV
Off road it will be great! On the road it will suck and might be illegal with respect to inspections.
Dissconnects are an easy fix and provide street stability and the offroad flex you are looking for.
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #3 of 3 Old 09-06-2012, 08:45 AM
jwmbishop
Accidental Obfuscator
jwmbishop's Avatar
2011 JK Wrangler
I think your nomenclature is a bit off.
You have one sway bar that is connected to the axle housing with two swaybar links...
You can replace just the one missing link - but it MUST be the same length as the other side, many lifts use the stock rear sway links (longer than stock fronts) up front so be sure to measure the link you have before ordering! AND you can setup the disconnect (for off road use) at the same time for very little $$.
J Wm Bishop EA, ASADE
The wagon should, of course, be as light as possible, but strength should not be sacrificed to lightness, for on any but the regularly traveled roads, the wagon will get many a
jwmbishop is online now
Sway Bar question like2lean TJ Wrangler Technical Forum 3 01-24-2012 07:53 AM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
sway bar question mean90yj YJ Wrangler Technical Forum 2 02-23-2007 08:34 PM
sway bar question yellowjeepin YJ Wrangler Technical Forum 1 04-20-2005 09:06 PM
Sway Bar Question wild_weazel YJ Wrangler Technical Forum 1 01-24-2004 12:37 AM
