Sway bar light flashing sparadically - JeepForum.com
post #1 of 5 Old 12-22-2012, 10:32 AM Thread Starter
marmotmb
2007 2dr, rubicon. Last few weeks my sway bar lights has been flashing all on its own. Had not manually actuated it in months. Usually it stops during a drive about town, sometimes not. Sitting overnight however its always off in the morning.
I did try to actuate it just incase it needed to be dis engaged then re engaged but it still flashes sparadically.
Any ideas ?
Pro Comp - Hypertech Programmer / 2.5" Teraflex coil lift & 1" M.O.R.E Body Lift / 315/75R16 Pro Comp Mt. Extremes / 16" x 8" Pro Comp Series 52 (Black) / Pro Comp steering stabalizer / Air Raid Cold air intake / Ace Enginnering and Fab Front stubby with bull bar / OR Fab Rear tire carrier / 2 Blitz Jerry Can / HI lift jack / Cherry Bomb 2.5" Exhaust and Custom Tail pipe / KC Daylighter 6" 130 Watt with Driving lense / Shifter boot trim ring bolt mod / Rear Bumper gap mod / Mirror drill hole mod
marmotmb is offline
post #2 of 5 Old 12-22-2012, 01:37 PM
RockyClymer
RedRock4Wheeler
RockyClymer's Avatar
Check wiring connections to actuator under front bumper...
08 JK 23S - Colorado Jeep Club No. 204
Too much to list - see my profile for details on build
16 JK Rubi with all the trimmings
NRA Life member
"It takes a special kind of stupid to believe criminals will follow gun laws."
I do not consider myself a smartass. I point out the obvious, search for the truth, and speak fluent sarcasm. I am, by experience, an accomplished curmudgeon.
RockyClymer is offline
post #3 of 5 Old 02-07-2013, 08:51 AM Thread Starter
marmotmb
Home sick today so updating a few posts.
Sway bar light hasn't flashed at all since I stopped a rad leak on Jan 10.
The leak was dripping down onto the sway bar motor a bit. I think the rad fluid was causing the flashing.
I have had this same issue when on the trail, starting to think that if water gets into the connector or somewhere else on the motor the ECU thinks there is a problem and flashes the dash light.
marmotmb is offline
post #4 of 5 Old 02-07-2013, 03:41 PM
GPV
Sounds like there may be an issue with the plug. Maybe smear some dielectric grease around the seal and plug it back in..............................
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline
post #5 of 5 Old 04-05-2013, 07:52 PM Thread Starter
marmotmb
Stupid sway bar light flashing again grrrr...... Been on for three days now.
marmotmb is offline
