I'm about to put a teraflex leveling kit on. 2" in the front 1" in the rear on my 08 jku x. It comes with new swaybar links and I was wondering if you can make the teraflex disconnect pins work with the leveling kit sway bars? http://www.quadratec.com/products/16191_6900.htm
might I be of service ? I went thru this when I first lifted via the TF leveling kit and got irate due to the old I instructions that TF sent showed the QD kit (as well as the ad in QuadraTec ) well, they finally got sick of my *****ing and sent it but sing then ( & having a recent upgrade to a more capable lift via Synergy Stage 1.5) I still tried to use the TF end links and they were the most decomposed and beat up cheap polyurethane pieces of junk ever . you will ( I mean it ) develop a popping clunk once the bushing wears even a little so just go in knowing you'll be looking for an alternative within 6-12 months if you ride it hard . I got the rough country kit and even it is better the. using the TF QD solution ; ever check out the TF demo Jeeps ? they have JKS or RE end links on those that don't have the electro disconnects .....just a helpful suggestion
Jeep On !
via iPhone JeepForum (so I'm sorry about the spelling & grammar mistakes!)
Hmm, I may give the pins a shot. If they don't work/last ill look into jks.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
