#1 | |
sway bar disconnect
hey folks.
does any one know if i can put a sway bar disconnect on my jk x ? is it tough, expensive etc. thanks ctown67
#2 |
Force Wheeler
Sure, you can put one on there, don't know how tough it is, etc...
Now if you are talking the factory electronic one, I don't know for sure if you can upgrade aftermarket...I ASSUME that you can, but I don't know if that would break the bank or not, sure it is a lot for expensive then the disconnects you could buy from quadratec, etc...
2007 White Jeep Wrangler X-auto, black freedom top, 15x8 Pro Comp Rock Crawlers, 33x12.5x15 BFG KM2s, Superchips Flashpaq, 2" OME Spring Lift, Rancho RS5000 shocks, Rusty's Adjustable front and rear trac-bar, JKS Quicker Disconnects, Rusty's adjustable lower control arms (front and rear), PolyPerformance adjustable upper control arms (front and rear), OEM Rubicon Rock Rails, Finishlinewest Stonehenge Series rear bumper, Smittybuilt winch, Body Armor Front High Clearance Bumper w/ KC Highlights mounted, Roadmaster towbar, Valley 2" receiver hitch, Skid Row Engine Transmission skid, sPod switching system, KC Highlights windshield mounted lights, and Bestop saddlebags-Member of the United Four Wheel Drive Association and Blue Ribbon Coalition, John 3:16 If you want to help the sport of off-roading, and protect your right to do so, please visit the Envirobeat forum... |
#3 | |
I have the JKS Quicker Disconnects on my X- cost around $130 for the pair. Took less than 30 minutes to install them. Now when I go off-road, it takes me just a couple minutes to disconnect. And re-connecting is very simple afterwards as well.
for details and info on our JK's, check out http://n2rock.com His: '07 Unlimited X, Jeep Green, Hardtop, auto, 5.13, 2.5" RC lift and too many mods to list Hers: '08 X Red Rock, soft top, auto. Bunch of mods Quote:
#4 | |
I've heard people gripe about how much of a PITA it is to do when muddy, etc. Just drive to your car wash and connect them there. I've driven up to 1,000 miles with my SB's disco'd and as long as you drive normal, there's zero issue. Spend the money elsewhere or just get a set of $100 quick disco's if you insist on the mod. |
#5 | ||
#6 | |
I would disagree. A flip of a switch beats getting under it any day. O and i own an X and manually disconnect mine too. There isnt always level ground around either... THey break because people lift and leave the stock links and then it binds during flex and ends up breaking. I personally know and wheel with a guy on 37" tires with a 4.5" lift who uses his E-disco with no issues |
#7 | |
Sure - if your rig came with it from the plant, then great (ie.,Rubi or pkg option). However, someone without it who is considering a purchase and install... no way. As for the level ground; there's nothing saying that you need to reconnect the minute your done wheeling. A close parking lot will easily suffice. I've done mine many times on ground that is not quite level and its just a matter of my 100lb fiance standing on a door sill to even it out. |
#8 |
there isnt always level ground around to disconnect is what I meant...
#9 |
thanks for the advice
ctown67 |
#10 | ||
#11 | |
#12 | ||
With the JKS's disco's, they pop right off. It has changed my prep time from 10 minutes to a couple minutes Likewise at the end of the day, I was done and standing there watching him still hooking up his first. Afterwards, he says "OK, I'm sold! Where do I buy those damn things" ![]()
#13 |
I had the JKS ones on my TJ and worked pretty well. I ended up bending one beyond repair and went the the Rubicon Express Gen 2 and I actually preferred them better. I know they make a Gen 2 for the JK, but I think they are for lifted and not stock height. Just another option.
PRESENT : 2008 Rubicon Unlimited | Rescue Green | OME HD Long Travel Kit w/ 40+ Coils| 37 x 12.5 BFG KM2s | Spidertrax Spacers | ProComp Extreme Alloy Wheels | Poison Spyder BFH Front Bumper | ARB Hi-Flow On Board Air | sPOD | Cobra CB |
#14 | ||
#15 |
That is definatley a better design than the TJ version. If i remember correctly they swung up and you pinned them up. I lost a pin on one of mine and it was dangling down and got beat up pretty bad.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
