Sway Bar - JeepForum.com
post #1 of 4 Old 07-16-2013, 11:46 AM Thread Starter
duane5157
Sway Bar
HI all, New jk 4 door owner,with rubicon springs and shocks. The question is does the jk have a sway bar or some other gear in the back of the vehicle. The jk seems to sway or roll pretty easy when changing lanes. Is there a cure for this or is this a jeep thing. Any clarification is greatly appreciated. Duane 5157
duane5157 is offline
post #2 of 4 Old 07-16-2013, 12:26 PM
222Doc
222Doc's Avatar
as long as the person that installed the springs assembled the Jeep back right. It should be a bit stiffer ride, you wont get much out the springs since it is a 4d anyway. the shockers better, being gas.
Its a high clearance vehicle, it wont handle like a car. Jeeps have never been a good car, nor truck/modern SUV's. It is a Jeep still with all the comforts they have added.
yes it has a sway bar front and rear.
222Doc is online now
post #3 of 4 Old 07-16-2013, 01:25 PM Thread Starter
duane5157
Thanks , its under warranty I guess I will have someone at the dealer check it out duane5157
post #4 of 4 Old 07-16-2013, 01:51 PM
GauchoMark
2011 JK Wrangler
do you have heavy bumpers? Adding weight increases your sway. If so, you can buy heavy sway bars to fix it.
Also, the sway bars are pretty visible if you just need to see if they are still hooked up - poke your head in the wheel well.
GauchoMark is offline
