Suspension upgrade for the weight of bumper and winch - JeepForum.com
post #1 of 36 Old 04-16-2012, 08:11 PM Thread Starter
teeking
Hi All,
We just bought a new Unlimited Arctic Edition and we are planning to add a Warn bumper and winch. The total weight of the two will be 200 lbs or more, what can we do to keep the front end from sagging/losing clearance.
I am wondering if we can just replace the coils and the shocks?
We really don't want to touch the rear end if possible.
Thanks,
Tee
teeking is offline
post #2 of 36 Old 04-16-2012, 08:34 PM
jaxs1984
2009 JK Wrangler
Hey welcome to the forum Those Arctic Edition are really nice looking. The cheapest solution would be to get some spacers. There are tons of companies that make them and range from 40. all the way to several hundred.
The companies are ARB, AEV, Rubicon , Teraflex... just goto http://www.quadratec.com/ and search spacers. You'll be overloaded with info
But, what I learned is that any mod is just the beginning and next thing you know you get obsessive. For example, I added a new bumper and winch which sag'd the front. So then I need a rear bumper/tire carrier to "level" it out. I then bought a 2.5' lift but it made my 32' tires seem "small" so now I'm looking at 33-35. Now I have the clearance to do some serious exploring but my 2DR is getting kind of tight with all the camping gear, etc... So now I'm debating if I need the 4DR...It never ends... Did I mention the underbody armor I know need
Congrats on the new Jeep
jaxs1984 is offline
post #3 of 36 Old 04-16-2012, 08:35 PM
buns79
Just get you some 3/4in or 1in coil spacers for the front end, no need to replace the coil unless your doing a lift. IMO
Good luck
13 jku 6sp, 4:88s, elockers, 3.5" RK, Ps fenders and front bumber, ace rear, 37" km2s Olllllll0
buns79 is offline
post #4 of 36 Old 04-16-2012, 08:48 PM Thread Starter
teeking
OK, I'll check out the spacers. Thanks for the quick responses!
teeking is offline
post #5 of 36 Old 04-17-2012, 03:55 AM
TheBoss
Spacers won't fix sag. The extra weight is compressing your coils you need a longer spring up front with a higher rate. If you only want to level it out without lifting the rear you should look into the Teraflex leveling kit with replacement coils. This will level the Jeep in relation to the back. Takes up the weight of the front bumper and winch. You can run up to a 33" tire on correctly backspaced rims without rubbing (in most cases).
TheBoss is offline
post #6 of 36 Old 04-17-2012, 04:02 AM
SubAtomicGenius
2011 JK Wrangler
Spacers will prop up your front and make it "look correct" for sag/droop. They are the cheapest solution, but the correct one is to get new coils/springs, especially if you plan on using it offroad.
SubAtomicGenius is offline
post #7 of 36 Old 04-17-2012, 08:14 AM
eastncjeep
2009 JK Wrangler
if you plan on adding a heavy rear bumper, you might want to factor that in as well.
'09 Sahara Unlimited ~~ Body Armor Quad Hoop Front Bumper, Daystar 1 3.4" BB Lift, 285/75/17 Nitto Terra Grapplers, KC Apollo Fogs
eastncjeep is offline
post #8 of 36 Old 04-17-2012, 08:28 AM
wardo
2011 JK Wrangler
Go with the RK 2.5 stock mod lift. levels the who set up out and gets you a lift. I have my RR xhd bumper on the front, adding the winch (just about done getting fixed) this weekend. Even with the bumper and the winch it doesn't drop the front that much and looks great. Spacers are cheap in every sense of the word. If you plan to ever lift it, do it now and do it right the first time. Best of luck and happy modding!!!
2011 Flame Red 2dr Wrangler Rubicon, Poison Spyder Evap Skid, Extended Breatherlines, 4' Firefly Antenna, Uniden Pro520xl, Rock Krawler 2.5 Stock Mod Lift, Bilstein 5100's, Rugged Ridge XHD Front Bumper, Warn M8000, Rugged Ridge XHD Snorkel
wardo is offline
post #9 of 36 Old 04-17-2012, 07:54 PM
MudDuck99
2014 JK Wrangler
With the RK 2.5 stock mod lift, will I just need shocks to complete the lift?
Also, Would adding Unlimited coils to the front compensate for the extra weight?
MudDuck99 is offline
post #10 of 36 Old 04-18-2012, 03:57 PM
HikerX
2014 WK
I went through the same thing recently. ARB bumper + 10k winch + existing rake meant the front end would be pretty low. I talked with OME several times trying to determine what coil to try. I ended up with a spacer to start out with so that I could correct the exaggerated rake. With a spacer you can choose exactly how much to compensate with. Springs you need to factor in how much lift it's supposed to give with the added weight.
Longer term I'm going with coils but right now the spacer was easier to calculate. last thing I wanted was to use new coils up front and ride high up there.
'14 WK2 Limited
Previous Jeeps
'11 JKU - '96 XJ Country - '04 TJ - '86 CJ7
HikerX is offline
post #11 of 36 Old 04-18-2012, 06:06 PM
MudDuck99
2014 JK Wrangler
How big of a spacer did you use?
post #12 of 36 Old 04-18-2012, 07:33 PM
HikerX
2014 WK
Rubicon Express 1.75" coil spring spacer from Quadratec. I probably could have gotten by with 1.5". When I chatted with the OME guys (ARB Technical support) they recommended the 2616 coil, which is listed as a 2" light load coil. With my added weight it might have leveled it out. But, $160+ for the coils was more of a gamble than I wanted to take at the time. Might still though...
Keep in mind if all you're trying to do is level out the front end, you shouldn't have to install new shocks that would match the height of the advertised lift. In my case, I gained back the rake the Jeep had in the first place, plus what the added weight did. If I netted 1.75" in height to the Jeep, then I would have considered new shocks that allowed for the extra height.
'14 WK2 Limited
Previous Jeeps
HikerX is offline
post #13 of 36 Old 04-18-2012, 07:55 PM
Jeffro06
Jeffro06's Avatar
Odds are your Jeep won't sag, immediately. Take measurement from the ground to your fender and keep that. Install the winch and bumper, drive it for awhile, like a few months. Let the springs do what they do. When it's sagging take that measurement again, it'll tell you how big of a spacer to get. I went with a 1" billet spacer from Rokmen for my TJ, they won't break down or wear out.
Rokmen Spacers
Jeffro06 is offline
post #14 of 36 Old 04-18-2012, 08:06 PM
joe002
My Jeep immediately sagged 3/4" when I added a metal bumper and winch. A spacer would just be a "band aid" for a sag. To "fix" a sag you need new springs (the shocks won't help with a sag - I still have my stock shocks, but new springs with no sag).
2008 Rubicon - 2 Door - Flame Red - Automatic - MyGIG - Power Group - Deep Tint.
AEV Pintlers, BFG KM2s 35x12.50x17, Bulldog Fab Stubby Bump, Currie F/R Adj Trac Bars, Daystar Upper Dash, FireStik FireFly antenna, Kilby Rear Shock Skids, LoD Sig Stubby Bump, Midland 75-822 CB, Mopar Filler Door & Locking Gas Cap, Rancho LCA Skids, Rancho Oil Pan Armor, Riddler Diff Covers, custom Rubi Sliders, Sylvania X-treme Headlights, TeraFlex 2.5" Spring Lift, Warn PowerPlant HD, Woods Evap Can Relo, Woods SS Relo, Yukon 5.38s
joe002 is offline
post #15 of 36 Old 04-18-2012, 08:37 PM
ncb
What are the last two digits of the part number of the front coils? If you want to remain stock get a set of -19 coils and add a small spacer.
ncb is offline
suspension
Bumper/winch too much weight? durable1 JK Wrangler Technical Forum 9 03-13-2011 09:39 AM
JK Bumper/winch weight problem noah2626 JK Wrangler Technical Forum 28 03-09-2011 06:10 AM
Spring Rates V. Travel (weight of bumper & winch) Running925 TJ Wrangler Technical Forum 17 08-12-2010 01:03 PM
avg bumper/winch weight? rballman JK Wrangler Technical Forum 2 09-15-2009 01:35 PM
First Upgrade - Winch! Plate + Weight ?'s Gailon TJ Wrangler Technical Forum 11 07-08-2009 04:05 PM
