Surviving the Frozen Northern Yankee Wasteland: ArticRubi's Build Thread - Page 31 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > JK Wrangler Technical Forum > Surviving the Frozen Northern Yankee Wasteland: ArticRubi's Build Thread
Poly Door Hinge BushingsStainless Steel Door Hinge PinsNew Knuckles Skid Plate at JeepHut
Unread 06-28-2012, 05:41 PM   #451
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Originally Posted by molshove View Post
I like white wheel with black ring...may do the same with mine (red wheel, though), to bring some color back to my black Jeep
Yeah..I saw Planman has white wheels on his rig, can't remember what color ring though. It looks good. I may also do white wheel, bare ring...one time on the trail and I'm going to scratch half the black off anyway.
From Rubicon to Icon - 4-link, Tons, Atlas Build
Build Thread
Need parts? Need product advice? Contact Jason at Krawl Off-Road
ArticRubi is offline   Reply With Quote
Unread 06-28-2012, 08:02 PM   #452
spedly
2011 JK Wrangler
I've been thinking of doing white trailreadys with anodized black rings. I think white and polished would look good too though. I'm jealous of your tires. A guy I wheel with has the 40's and the lugs just wrap around everything. I'm interested to see how the JK axle holds up to the 37" version.
Poser Jeep.
spedly is offline   Reply With Quote
Unread 06-28-2012, 08:30 PM   #453
ArticRubi
Arrogant SOB
ArticRubi's Avatar
After thinking on it for a bit, if I do anything it'll be white and polished. Black rings won't hold up at all...just not going happen. I'm hoping I don't find the weak link in my drive line because of these things. I should be doing the RCV install tomorrow, so I'll have alloy shafts front and rear, same with the R&P and drive shafts. I'm thinking when something goes its probably going to be the locker.
I'm working on figuring out how I want to do 60's now...
There's the junkyard route, and adding the Dynatrac tone ring retrofit kit.
Buying some RJ 60 housings and building the rest myself.
And the obvious (expensive) choice is to get crate axles.
If I blow up the 44's in short order, I'll just repair whatever breaks, I should be able to sell them off for some pretty good coin considering how they're built.
Although the crate route is the easiest, I don't learn much from it. Most likely route is to buy RJ60 housings and setup the rest myself, even if I don't save a lot of money doing so vs buying turn key axles.
Build Thread
Unread 06-28-2012, 11:25 PM   #454
DrHolliday
DrHolliday's Avatar
2011 JK Wrangler
You do learn a lot doing your own gears. Gears where the only thing I had never done before I got my Jeep. I didn't want to spend the 1-2k labor that shops around here wanted to charge. After doing a lot of reading I tackled it with the help of a friend. After doing it I don't know what I was scared of. You learn a lot and realize how simple it really is. Just takes time getting the shims set up.
2011 JK Rubicon 2 door 6-speed manual, 3.5" Rock Krawler Suspension lift, 1.25" Daystar body lift, 40x13.50R17 Nitto Mud Grapplers
My build thread
DrHolliday is offline   Reply With Quote
Unread 06-29-2012, 08:34 AM   #455
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Yeah I'm honestly not real intimidated by it any more. There's a great article/how-to on Pirate that was really helpful. The part that is a bit more difficult will be setting up all the brackets and getting that geometry correct.
Currently waiting on the sun to start the RCV/Reid knuckle/Currie tie rod install. Went by Advanced earlier and picked up their loaner ball joint press kit, hoping to be able to tackle this job in a few hours.
Build Thread
Unread 06-29-2012, 08:39 AM   #456
DrHolliday
DrHolliday's Avatar
2011 JK Wrangler
Have your torch handy... heat helped get the lower joints to bust loose on mine.
My build thread
Unread 06-29-2012, 08:54 AM   #457
Mol
Disclaimer: I'm Polish
Mol's Avatar
This - if you have a decent impact, the puller should pop em out with a little persuasion, though
Don't forget to grind your steer stops down...a little at a time with regular checks, to avoid over grinding
2008 JKUR
Raceline - Maxxis - Currie - Synergy - Offroad Evolution - Reid Racing - RCV - Pretty ****ty Crap (PSC) - River Raider - Warn - MBRP - KC - AEV - Offroad Heros - BFG - Teraflex - BDS - Fox - Eibach - Moog
2012 JKU
- The smoking hot wife mod -
Mol is offline   Reply With Quote
Unread 06-29-2012, 02:16 PM   #458
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Very true. Popped the uppers pretty easy, I'm about to break out the Oxy torch for the lowers....I compacted the threads on the press trying to remove them :O Guess I need to get off the roids (joking)
Build Thread
Unread 06-29-2012, 02:24 PM   #459
Mol
Mol's Avatar
2008 JKUR
2012 JKU
Unread 06-29-2012, 02:39 PM   #460
DrHolliday
DrHolliday's Avatar
2011 JK Wrangler
Yeah, just heat the lower part of the C and it will pop out a lot easier.
My build thread
Unread 06-30-2012, 10:47 AM   #461
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Ended up getting everything torn down last night except lower ball joints. Didn't really feel like lugging the Oxy torch up at that point in the day. About to get started on that now, first order of business was to throw 4 racks of my Memphis dry rub ribs in the smoker.
Build Thread
Unread 06-30-2012, 05:25 PM   #462
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Pissed. Looks like I received a bad upper ball joint from Synergy. The stud won't move in the ball at all, even tried hitting it with a mini sledge and it still won't move. The angle that's it's seized is too great and the knuckle won't fit over it. Tried sliding the knuckle over the ball joints and hitting the bottom of the knuckle with the sledge and instead of the stud straightening out the ball joint start coming unseated from the C. Tried taking the ball joint out and reseating it at a couple of different angles, same result.
Build Thread
Unread 06-30-2012, 05:53 PM   #463
1222
Make mine a Jeep!
1222's Avatar
Man that sucks and it always seems to happen on a weekend too. Were you able to call them and have a replacement shipped to you, next day?
1222 is offline   Reply With Quote
Unread 06-30-2012, 05:57 PM   #464
ArticRubi
Arrogant SOB
ArticRubi's Avatar
Tried calling both Poly and Northridge, no one open today :thumbsdown:
Cant even put the stock one back in, it came apart when I pressed it out.
Build Thread
Unread 06-30-2012, 06:47 PM   #465
TheBoss
within the mind
TheBoss's Avatar
I'm sorry I keep looking at the picture of those ribs and can't seem to find a problem here.
Seriously though that sucks ,but I'm sure they will take care of you.
JK : AEV, Synergy, JKS, Teraflex, Bilstein, GoodYear, M.B, LoD, Ramsey, Hella, Uniden, Smitty-re-bilt rails, Safari Straps
WJ : BDS, Teraflex, JK Rubicon shocks, GoodYear, JK wheels
"I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them." Thomas Jefferson
TheBoss is offline   Reply With Quote
